Cannot Append Palette As Local Datablock #48965
Reference: blender/blender#48965
The enclosed example file with palette.blend contains a colour palette. I used to be able to use the “Append” command to copy a palette into a new
.blend
file, but this no longer works: now it seems to be linked, and what is worse, the option to “make local” is greyed out.Also, the “Append” function now seems to add
.blend
files appended from as libraries within the file being appended to. I thought this only needed to happen with linking, not appending.Changed status to: 'Open'
Added subscriber: @ldo
Added subscriber: @Sergey
Bastien, guess this one is for you :)
@ldo technically, append is a link followed by a 'make local' (which also removes the lib). So what’s failing here is the 'make library local' stage ;)
This issue was referenced by
035b40337a
OK, I can now bring in a local copy of the palette, thanks.
But I see it still links the file being appended from as a library, which it didn’t used to do before. So it is not removing the library as you say.
Changed status from 'Resolved' to: 'Open'
Bug has resurfaced: appending is causing linking again. And not just palettes this time, either.
Fixed in
912f46d309
, thanks.OK, it works again, thanks.
I suppose I should open a separate bug for the other issue.
Yes please.
