Custom Properties within PropertyGroups cannot be animated when attached to a PoseBone #48975
9 Participants
Reference: blender/blender#48975
Ubuntu Linux 14.04 (64-bit)
NVIDIA GTX 960 (NVIDIA Driver Version 367.35)
Broken: 2.77a
abf6f08
Worked: N/A
I've found that custom properties stored within PropertyGroups and/or CollectionPropertys cannot actually be animated if they are associated with a PoseBone (Error returned when inserting keyframe is "Failed to resolve path to property, try manually specifying this using a Keying Set instead"). (If the exact same custom properties are associated with an Object, they can be animated by inserting keyframes normally.)
It's possible that I'm mistaken and it is possible to manually specify the property within a CollectionProperty/PropertyGroup using a Keying Set in a more straightforward manner (or at all), but to manually add a Keying Set for every potential instance of a property within a CollectionProperty for every PoseBone that uses the custom properties is an unrealistic for any use case involving a CollectionProperty (and honestly I'm doubtful whether this is even possible, I was unable to successfully create a Keying Set for keyframing a property within a CollectionProperty/PropertyGroup, getting error 'Keying set failed to insert any key frames', although I can't deny the possibility I got the path to the property wrong somehow).
bug_report.zip
Added subscriber: @sn0w75-4
I've added a second .zip (bug_report_2.zip) that contains a revised version of the add-on used for showcasing the bug that adds a section under the Object panel so you try setting keyframes for custom properties within PropertyGroup/CollectionPropertys of Objects as well as PoseBones (it works for Objects, but not for PoseBones).
bug_report_2.zip
Added subscribers: @JoshuaLeung, @Sergey
A bit weird. @JoshuaLeung, mind having a look here? :)
P.S. It's not required to install the addon, script can be run from text editor in Blender.
Added subscriber: @GrahamHeld
This "bug" is still present in the official 2.78 RC as of 9/11/2016. I just ran in to this while working on my own addon involving PoseBones.
The conditions in my scene file and property setup are virtually identical to the ones described above.
@GrahamHeld
FYI, I did a workaround for this by, instead of storing the properties within a PropertyGroup or CollectionProperty, to just associate a set of custom properties directly with the PoseBone that use a naming scheme you can use to 'emulate' an array/CollectionProperty. (Since custom properties associated directly with the PoseBone that aren't inside of any PropertyGroup/CollectionProperty can still be animated.)
So, for example, if you wanted an array of a particular type of custom property, you'd make a set of variables that look like this:
num_things
thing0_propA
thing0_propB
thing0_propC
thing1_propA
thing1_propB
thing1_propC
etc...
It's a very dirty workaround imo, but it'll get the job done if you don't have time to wait for a fix.
This worked for my use case since I knew I wouldn't need an array size of more than a few items,
But for a use case that involves tens or hundreds of array items, this may not be a great workaround.
Added subscriber: @dr.sybren
This is apparently a known limitation, it's documented as TODO in
rna_path_from_ID_to_idpgroup()
(the TODO was added in19efa4301a
in 2010). As such this isn't considered a bug. It's still clearly useful functionality, though, so I'll mark it as a To Do.Added subscriber: @tylerfurby
Any status on this becoming implemented? Have quite a few properties written in collection properties in an add-on of mine -- none of which are related to rigging or bones.
At this time there is no concrete plan to implement this.
Added subscriber: @pauanyu_blender
Added subscriber: @geloescht
Added subscriber: @Solstice245
Here to second this...this limitation also affects pointer properties. Fortunately for me though that is much easier to work around.
I am willing to tackle this, as it hinders my add-on development greatly. However I don't have much experience with the blender C source, so some advice from the veterans is appreciated. Scanning the code and stepping through the involved functions I came up with two possible solutions.
idp_owner would point to the object that holds the ID property being pointed to or NULL if it isn't an ID property. Thus is would be equal to owner_id if it is held by an actual ID type or point to a PoseBone, Sequence, etc. otherwise. We should be able to figure out the path of idp_owner in the same way as with any other plain RNA property and tack on the path of the ID property. Hopefully the increased size of the struct won't matter too much because afaict PointerRNA isn't used by value very often. If this doesn't make any sense or this tradeoff is unacceptable, please let me know.
The other possibility would be to add some kind of virtual function on the same level as StructRNA.idproperties that allows us to iterate over all nested properties of an ID datablock that can possibly hold ID properties. The function doesn't necessarily need to be defined on StructRNA as it is only needed for ID types, but I am not sure where would be the best place to put it. We then search all of those in
instead of just those of the ID type. That would keep PointerRNA the same but the performance could be worse, especially when there are many ID properties defined, and custom methods would have to be written and maintained for every ID type.Lastly it might be possible to iterate over all RNA properties of the owner ID datablock recursively and find those that can hold ID properties. Python knows all properties, so it should be doable somehow, although I am not sure how it works. The performance would probably be abysmal, so I haven't looked into this.
Can you advise me if any of these plans sound reasonable, @dr.sybren?
Added subscriber: @mont29
For this I would actually appreciate @mont29 's feedback :)
After spending more time with the code I decided that the alternatives I proposed require changes in too many places to be practical. Instead I came up with a hack of sorts where a reference to the struct that owns the ID property group and its type is stored in unused fields of
IDProperty::data
. It is propagated to any property that is added to an IDP_GROUP or IDP_IDPARRAY.rna_path_from_ID_to_idpgroup()
uses this ownership reference if it exists to search for the ID property in the right place and builds a path.Creating and updating the reference after loading a file happens in the
idprops()
function for each type. It was the easiest place to do add that, otherwise RNA stuff would have to be added in places that doesn't deal with RNA. I can see how something might go wrong here but so far haven't encountered any problems.The attached patch is a proof of concept and shouldn't be seen as a patch to be committed immediately. My question is if this is acceptable as an approach since it is kind of a hack (but on the other hand the way ID properties are stored already looks like a hack to me).
T48975_poc.diff test_animate_sequence_props.blend1
In the attached example, run the script in the text editor and navigate to the sequence editor. In the test tab, try to insert keyframes on the nested ID properties of the sequence. With the patch applied, this should work.
I realized that attaching a diff as a comment is not the right way. Sorry for this, see D11652
Added subscriber: @Mets
I'm curious if any progress has been made here? I'm very much looking forward to it.
My diff seems to work for me (though limited to sequences and pose bones atm) but I haven't gotten any feedback from more experienced developers. I wouldn't want to spend more time on it without knowing whether it could possibly be accepted, especially since it is kind of a hack.
