Unicode strings in ID properties cause UI glitch #48992
2 Participants
Reference: blender/blender#48992
Kubuntu 16.04
Broken: 2.70a, 2.77a and
7065022f7a
(2.65a also fails, but just shows an empty value)Worked: 2.60a
When an
EnumProperty
gets its values from a function, which uses an Unicode string from an ID property, the UI gets corrupted.Exact steps for others to reproduce the error
This is the code from the blend file that triggers this error:
assert self['id_value'] == '½k'
return [
('buggy_key', self['id_value'], 'This value is very buggy in the GUI'),
('okay_key', '½k', 'This value is just fine'),
items=get_items)
bl_label = "String bug panel"
bl_idname = "OBJECT_PT_hello"
bl_space_type = 'PROPERTIES'
bl_region_type = 'WINDOW'
bl_context = "object"
def draw(self, context):
self.layout.prop(context.object, "buggy_prop")
bpy.utils.register_class(StringBugPanel)
bpy.utils.unregister_class(StringBugPanel)
register()
As you can see, the bug doesn't manifest itself when the string is a pure Python string (the 'okay_key' value). However, it fails if it is stored in an ID property, even though the two are considered equal in the Python domain.
Update: I've tested to create a copy of the string, using
self['id_value']- [x]
andstr(self['id_value'])
, but that also gets corrupted. Concatenating with'xx' + self['id_value']
also gets corrupted.Changed status to: 'Open'
Added subscriber: @dr.sybren
Added subscriber: @brecht
I suspect it's the same as issue as blender/blender-addons#48873.
Closed as duplicate of blender/blender-addons#48873
