Last Nvidia drivers (372.70) and Blender (2.77a) turn off Windows Aero
Windows 7 Ult x64
780GTX Drivers 720.70
Broken: 2.77a with drivers 372.70 or 372.54 (Not tested with this one, but I read somewhere is broken too)
Worked: I used an older version but I read this work until 368.81 without problems
At open Blender with the last Nvidia drivers (372.70 ), Blender (2.77a) turn the Windows 7 Aero off.
Install the last Nvidia drivers 372.70 restart or no then open Blender 2.77a, then the whole desktop turn Aero off.
Commits
rBf0159d1d48a1: Fix T49215
LazyDodo (LazyDodo) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.Sep 1 2016, 2:25 AM
Nvidia added a pixel format with 64 bit color in it (supports 64 bit color, but doesn't support PFD_SUPPORT_COMPOSITION) giving this format a huge advantage in weight_pixel_format. (and disables aero in the process)
This does the trick for me, Mike? Thoughts?
 intern/ghost/intern/GHOST_ContextWGL.cpp | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/intern/ghost/intern/GHOST_ContextWGL.cpp b/intern/ghost/intern/GHOST_ContextWGL.cpp
index abce3ea..e27065e 100644
--- a/intern/ghost/intern/GHOST_ContextWGL.cpp
+++ b/intern/ghost/intern/GHOST_ContextWGL.cpp
@@ -194,7 +194,7 @@ static int weight_pixel_format(PIXELFORMATDESCRIPTOR &pfd, PIXELFORMATDESCRIPTOR
 	/* give no weight to a 16-bit depth buffer, because those are crap */
 	weight += pfd.cDepthBits - 16;
-	weight += pfd.cColorBits -  8;
+	weight += min(pfd.cColorBits,33) -  8; // clip > 32 bit formats, so they don't get too much of an advantage
 	if (preferredPFD.cAlphaBits > 0 && pfd.cAlphaBits > 0)
 		weight++;
Also we don't really rate on PFD_SUPPORT_COMPOSITION unless WIN32_COMPOSITING is defined (which it is not) seems wonky as well.... given vista is now our lowest platform we should be able to enable this?
I need to freshen up knowledge of Windows pixel format options, but as a quick fix this looks fine. Minor change: why not this?
min(pfd.cColorBits, 32) - 8
Good & thorough article on "OpenGL and Windows Vista"
https://www.opengl.org/pipeline/article/vol003_7/
^-- based on this I'm not 100% sure we're doing everything necessary for PFD_SUPPORT_COMPOSITION (but we might be). Apply the above fix for 2.78 & we can do PFD_SUPPORT_COMPOSITION properly after.
Lots of magic going on in this pixel format weighting scheme.. I bet we can come up with something simpler for 2.8 or later.
TODO: Support deep display output for people with high-end monitors (10 bits per channel). Opt-in via System user prefs, not automatic.
LazyDodo (LazyDodo) added a comment.EditedSep 1 2016, 6:25 PM
Cause i figured, higher color depth, sure, have a +1 on 32 bit color, but not +32, I'm not overly dedicated to this though, awarding no points would be fine with me as well. We could also just flat out reject the 64 bit color profiles, return 0 and be done with it?
Yeah i read that yesterday while figuring out why it disabled aero :)
I think we're pretty close to doing everything it says , but it's all disabled with that WIN32_COMPOSITING define not being there.
I almost suggested to just turn it on, but then i bumped into some dwm drawing code who's purpose isn't entirely clear to me. (enabled it, didn't seem to do anything)
I say make a quick hack for 2.78 by using the patch above (with either 32 or 33, meh, don't care) and see how we can do this better for 2.8?
I think any bit depth > 32 will disable Aero.
You're probably right, how about this is a less risky solution ?
 intern/ghost/intern/GHOST_ContextWGL.cpp | 1 +
index abce3ea..64ee692 100644
@@ -183,6 +183,7 @@ static int weight_pixel_format(PIXELFORMATDESCRIPTOR &pfd, PIXELFORMATDESCRIPTOR
 	    !(pfd.dwFlags & PFD_DOUBLEBUFFER)    || /* Blender _needs_ this */
 	    !(pfd.iPixelType == PFD_TYPE_RGBA)   ||
 	     (pfd.cDepthBits < 16)               ||
+	     (pfd.cColorBits > 32)               || /* 64 bit formats disable aero */
 	     (pfd.dwFlags & PFD_GENERIC_FORMAT))    /* no software renderers */
 		return 0;
Yeah, that's better actually -- we don't want 64-bit format tying with a 32-bit one based on score. Better to reject them for now.
Commit!
This comment was removed by David (Hgdavidy).
