Incorrect Custom Float Property Value Readout #49304
Reference: blender/blender#49304
Windows 7 Enterprise 64 w/ NVIDIA Quadro K2100M
Broken: 2.77a
abf6f08
and 2.78 RC10e5089c
Assigning custom float property values to objects stores incorrect values. I've tried by creating properties via the UI as well as with python code:
import bpy
ob = bpy.context.active_object
ob['property'] = 987654.321
Doing so (in both cases) the property is set to the correct value internally, but the UI reports the value as 987654.313.
Other numbers are also coming up with incorrect decimal parts of the value.
Create a cube.
Add a new Custom Property using the UI or with the above code run via a text window.
Check property value via Python console (it'll be correct) and then look in the UI and see the incorrect value.
Added subscriber: @DarrenWaschow
Added subscriber: @BrendonMurphy
hi, tested this out & found the error occurs after more than 8 digits are added, less than 8 digits & there's no difference, more than 8 & there is wrong comparison.
Added subscriber: @mont29
Thanks for the report, but no bug here, that’s merely well-known floating point precision issue, you only have about 7 digits usable on 32bit floats, nothing to be done here.
Bastien:
I'm not sure your explanation addresses what's actually happening here. The value stored in the object's property is correct. It's just the value that's shown in the UI under Custom Properties that's incorrect.
If you assign a floating point value of, say, 987654.321 to an object property, you can then query that value using ob['property'] in the Python console and it's correct. But the UI shows the value as 987654.313.
See the attached screen shot.
Thanks!
@DarrenWaschow That’s precisely the point - our UI code does not draw raw float values, for various reasons, so it ends up applying some transformations to it (see
UI_calc_float_precision
function in code), hence the float precision issue…
