Bevel gives irregular result
Bevel gives irregular result in some cases.
In attached file:
  1. Edit mode
  2. Bevel selected edges
The upper one looks wrong. Result of the bottom edge bevel is expected for the upper one.
Using:
Blender 2.77
Hash: 22a2853
Windows 10
Thank you
Why would you expect the same result for the upper one? They have a completely different amount of connected edges.
Hi, result is not same even if I equalize amount of connected edges. From my point of view the issue is not dependent on this. See edges where arrow point. I would expect same smoothed result.
If I create same amount of connected edges I get mostly identical result.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Sep 16 2016, 11:38 AM
Indeed not sure there is a bug here… let's see what @Howard Trickey (howardt) thinks about it. :)
You have only one segment on bevel, add more. You will see the issue.
Sorry I forgot to mention in description.
