Microdisplacement: Checker Texture differences from camera view (not in geometry) #49364
Closed
opened 2016-09-15 18:53:07 +02:00 by YAFU · 4 comments
Kubunu Linux 14.04 64 bits, GTX 960
Broken: from buildbot ( 21e9db9 )
Some doubts I had about Checker texture and microdisplacement:
https://blenderartists.org/forum/showthread.php?396697-Cycles-new-microdisplacement-build-and-testing&p=3098698&viewfull=1#post3098698
https://blenderartists.org/forum/showthread.php?396697-Cycles-new-microdisplacement-build-and-testing&p=3098727&viewfull=1#post3098727
Blend file:
Bake checker internal disp-Cycles displacement.blend
Here I show the problem:
In short, opening the .blend file and switch to Rendered View it looks like the first image.
But if you Render Image or switch to camera view in Rendered view in viewport, it looks like the second image.
Open the .blend file and switch to Rendered view (shift+Z). Now switch to solid view (Shift+Z) and from camera view (Numpad 0). Switch to rendered view (shift+z). The same happens if you Render Image.
**System Information** Kubunu Linux 14.04 64 bits, GTX 960 **Blender Version** Broken: from buildbot ( 21e9db9 ) **Short description of error** Some doubts I had about Checker texture and microdisplacement: https://blenderartists.org/forum/showthread.php?396697-Cycles-new-microdisplacement-build-and-testing&p=3098698&viewfull=1#post3098698 https://blenderartists.org/forum/showthread.php?396697-Cycles-new-microdisplacement-build-and-testing&p=3098727&viewfull=1#post3098727 Blend file: [Bake checker internal disp-Cycles displacement.blend](https://archive.blender.org/developer/F360698/Bake_checker_internal_disp-Cycles_displacement.blend) Here I show the problem: ![checker.jpg](https://archive.blender.org/developer/F360696/checker.jpg) In short, opening the .blend file and switch to Rendered View it looks like the first image. But if you Render Image or switch to camera view in Rendered view in viewport, it looks like the second image. **Exact steps for others to reproduce the error** Open the .blend file and switch to Rendered view (shift+Z). Now switch to solid view (Shift+Z) and from camera view (Numpad 0). Switch to rendered view (shift+z). The same happens if you Render Image.
Author
Author
Added subscriber: @YAFU
Mai Lavelle was assigned by Bastien Montagne 2016-09-16 11:37:19 +02:00
Member
Member
This isn't a bug, whats happening is you have a very abrupt change from one point to another which causes the micropolygons to stretch, and when they stretch that much you can get shading artifacts. The solution is to avoid abrupt changes in your shaders, by using things like smoothstep or similar.
This isn't a bug, whats happening is you have a very abrupt change from one point to another which causes the micropolygons to stretch, and when they stretch that much you can get shading artifacts. The solution is to avoid abrupt changes in your shaders, by using things like `smoothstep` or similar.
2 Participants
Reference: blender/blender#49364
