Quicktime video file render result is corrupted
Open, ConfirmedPublic
iMac (Retina 5K, 27-inch, Late 2015) I have tried on older macs as well.
2.77, even tried of 2.74
After a complete render, the file (quicktime) - (h264) is only playable through playing the preview on finder. Played on quicklime it is just black. I experienced this error only the last 5 months.
The file is ready to be put on render. it does not matter if full animation is completed or cancelled before.
Thank you.
Bastien Montagne (mont29) renamed this task from Corrupted file after render to Quicktime video file render result is corrupted.Sep 19 2016, 10:25 AM
Sergey Sharybin (sergey) triaged this task as Incomplete priority.Sep 20 2016, 11:19 AM
Have you ever been able to export QuickTime video from Blender? If so, does that Blender version still work? Did you update mac recently? (current guess is that it might be related on the QTKit framework removed from recent builds).
@Martijn Berger (juicyfruit), are you able to test/reproduce the issue?
Brecht Van Lommel (brecht) raised the priority of this task from Incomplete to Confirmed.Sep 25 2016, 2:59 AM
I can confirm the issue in Blender 2.77. If I render at half resolution, change the video codec from H.264 to JPEG, or lower the quality from 100% to 80% it works.
I don't know if we are using the API wrong or if something broke in OS X. I can't spot anything wrong in our code so far.
At this point maybe we should discuss removing support for QuickTime in 2.8?
