2.78 RC2 - texture mapping distorted when using Experimental adaptive subsurf #49395
Closed
opened 2016-09-19 06:22:00 +02:00 by Jeremy Johnson · 6 comments
In Blender 2.78 RC2, the texture mapping seems to get distorted when enabling the experimental Adaptive Subsurf feature.
Attached is an example blend file test.blend. With a rendered viewport open, just toggle the "Adaptive" box in the subsurf modifier to see the issue.
Here's what I did:
Launch Blender 2.78 RC2.
Enable experimental feature set.
Subdivide the default cube in edit mode 2 times.
Alt-Shift-S and set to To Sphere to 1.0 to round out the cube.
UV Unwrap the cube with spherical mapping.
Assign an image texture to the material.
Apply a subsurf modifier.
Open a Rendered preview viewport.
As soon as you check the Adaptive box in the subsurf modifier, you see the texture get kinked.
Example without adaptive: correctmapping.png
Example with adaptive: adaptivesubsurfenabled.png
In Blender 2.78 RC2, the texture mapping seems to get distorted when enabling the experimental Adaptive Subsurf feature. Attached is an example blend file [test.blend](https://archive.blender.org/developer/F362905/test.blend). With a rendered viewport open, just toggle the "Adaptive" box in the subsurf modifier to see the issue. Here's what I did: Launch Blender 2.78 RC2. Enable experimental feature set. Subdivide the default cube in edit mode 2 times. Alt-Shift-S and set to To Sphere to 1.0 to round out the cube. UV Unwrap the cube with spherical mapping. Assign an image texture to the material. Apply a subsurf modifier. Open a Rendered preview viewport. As soon as you check the Adaptive box in the subsurf modifier, you see the texture get kinked. Example without adaptive: ![correctmapping.png](https://archive.blender.org/developer/F362907/correctmapping.png) Example with adaptive: ![adaptivesubsurfenabled.png](https://archive.blender.org/developer/F362909/adaptivesubsurfenabled.png)
Author
Author
Added subscriber: @JeremyJohnson
Mai Lavelle was assigned by Sergey Sharybin 2016-09-20 11:22:57 +02:00
Member
Known limitation
Known limitation
Member
Added subscriber: @Blendify
Member
Member
I do not think a task is needed for this. Subdivisions of UV's are currently not supported. To work around this add a subsurf and apply it then add another subsurf and use adaptive.
Reference: blender/blender#49395
