Cycles crash - can't use 5 Gigabyte Tile EXR texture file #49417
Reference: blender/blender#49417
Windows 10, AMD R9 390
Broken: (example: 2.69.7
4b206af
, see splash screen)Worked: (optional)
Loading a ultra high resolution map of Vietnam only a uv plane, 35k by 35k file, roughly a 5.4 gigabyte exr file. Viewport does not display texture. When I switch on cycles preview mode, it will crash/close blender, when I hit f12 to render, it will crash/close blender.
I would also like to use a 20k by 20k displacement map with the diffuse map to generate Vietnam. Thanks.
Based on a (as simple as possible) attached .blend file with minimum amount of steps.
Added subscriber: @ThomasCheng
Added subscribers: @Sergey, @Blendify
@Sergey I think you are the only one who might have access to hardware to test weather or not this is Blender or hardware related.
However, @ThomasCheng I can insure you that from what you have said about your hardware so far that you will never be able to render this image. As a side note, I am sure that you do not need a 35k texture, you will be fine with a much lower res image.
Hi Aaron
I'm currently on a project where we are doing a documentary on Vietnam in The Foundry Modo. We extracted the images from free government sites that provides them, which includes both the color map and displacement from geotiffs. We have 4 sizes of this image, 35k, 17.5k, 9k, and 4.5k maps for different animation needs. We have many shots requiring us to see large sections of Vietnam and zooming all the way down to a city. While there are ways to switch between the 4 different maps as we zoom in, due to the high number of shots needed, it would be faster and easier to use a single high resolution map to do all the work.
By comparison, we are able to load the diffuse and displacement maps into Modo on a machine with 16gigs of ram with viewport preview and rendering. It renders much faster with 32gigs of ram, due to harddrive paging? We would like to switch to Blender for the rest of the project if possible. Thanks.
BTW, we converted the 35k image into Tile EXRs, which only loaded in sections of the image needed for rendering. Perhaps, I should be requesting support for converting images to Tile EXRs and for Blender to read it properly? I can also provide the 5GB exr file by dropbox if you need it.
Cycles crash - can't use 5 Gigabyte texture fileto Cycles crash - can't use 5 Gigabyte Tile EXR texture fileWe don't use tiled cache at all in neither OpenGL viewport nor in Cycles. So converting EXR would not help here. So unless you have enough memory currently you can't render such scenes.
However, i'm trying to prevent Blender from crashing and give "Out of memory" errors in such extreams. Can you by any chance upload example textures somewhere? Maybe make them black so they are really small after compression.
Ok, sounds good. I'm giving them to you Tiled anyway, as we have a Tile EXR pipeline and Nuke use Tile EXR for more efficient compositing anyway.
Here are the Tiled EXR files.
Black - Tile EXR - 148MB
https://www.dropbox.com/s/5yfjtc9iatwo0an/Black_Tile.exr?dl=0
Vietnam - Tile EXR - 5.2GB
https://www.dropbox.com/s/9tcl33cm3wkmefa/Vietnam_Tile.exr?dl=0
Ok, on CPU this is a real bug in the code. Fix is incoming.
This issue was referenced by blender/cycles@318e45c20c
d84c55f0fa
Awesome :)
