adding features in Viewport render with OpenCL doesn't trigger a kernel recompile anymore
all vendors
Broken: 2.78
Worked: original patch from AMD for split kernel if I remember correctly.
When adding hairs for example while in viewport render, the kernel will not recompile, making the hairs invisible. User has to toggle twice the render mode for the viewport to get it display the scene correctly. No hints is given about what is wrong.
Start viewport render on the default cube scene and add a hair system. It doesn't render. Toggling to solid mode and back to rendered mode solves the problem.
Aaron Carlisle (Blendify) lowered the priority of this task from "Normal" to "Incomplete".Apr 20 2017, 7:23 PM
@john peterson (bliblubli) is this still an issue?
Sergey Sharybin (sergey) raised the priority of this task from "Incomplete" to "Normal".Fri, May 12, 4:08 PM
it is still an issue.
@Mai Lavelle (maiself), mind giving some help here? The issue here is that we'll need to somehow teach ccl::Session to re-load kernels when something changes.
