Normal map support in Cycles standalone #49573
Reference: blender/blender#49573
Windows 8.1 64-bit
Cycles Version
d553b8de7180
In the latest version available in the Cycles standalone repository, commit d553b8de7180, using a normal map node in a shader graph will cause Cycles to crash. This behavior was not present in release 1.7.0 but has been added since then.
This looks to be caused by an improperly initialized member variable in the ccl::NormalMapNode type. Upon creating an object of type NormalMapNode, the ustring named 'attribute' is initialized such that attribute.c_str() will return a nullptr.
Cycles crashes when the nullptr used to construct a std::string in NormalMapNode::attributes in this bit:
I have attached a simple cycles standalone scene that triggers this error here: sample_scene.xml
Added subscriber: @witthuhn
Added subscribers: @ThomasDinges, @Sergey
AFAIR, normal map requires tangent space, which in Blender is calculated using mikkspace. This library is not used by the standalone Cycles. So making normal map to work is a bit involved, but think we should still fix the crash.
@ThomasDinges, something fun for you to look into? ;)
Added subscriber: @kalpesh-2
Is this being addressed? Have a lot of gltf 2.0 assets with tangent space normal maps that just render black (no crash though). boombox.zip
Crash when using normal map node in cycles standaloneto Normal map support in Cycles standaloneAdded subscriber: @brecht
The solution here would be to move the tangent computation from the Blender exporter into Cycles itself.
