clipping border with smoke does not work anymore
Open, NormalPublic
Windows 8 64bit,
Broken: 2.78
Worked: 2.74
With 2.74 i was able to use clipping border to cut smoke into a slice for better analyzing.
With Blender 2.78 it does not work anymore.
open the file. if you see no smoke press ALT+A, wait for some seconds and press ALT+A again.
press ALT+B to clip border and select a slice of the cube + smoke
In Blender 2.74 it cuts cube + smoke into a slice.
In blender 2.78 it cuts the cube but does not touch the slice.
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Normal.Oct 14 2016, 3:26 PM
I would think this is related to OGL/Viewport, @Mike Erwin (merwin), @Dalai Felinto (dfelinto)?
This worked until 2.76b and it doesn't work since 2.77a.
I looked at the code and even if I comment out all the ED_view3d_clipping_disable calls, the problem persists.
Looking further the problem probably was introduced on rB0372b642 when smoke drawing was converted to GLSL.
Assigning to Kévin, in case he has a way of solving this.
