Select no longer works. Can not select vertex, edge or surfaces #49724
Reference: blender/blender#49724
Windows10;Intel Core i5-6400 CPU NVIDIA GeFOrce GT 730
Version 2.78
Worked: 2.77 Version Worked
Uninstalled and reinstalled both msi and zip. Problem still exists.
Added subscriber: @mvalliere
#49725 was marked as duplicate of this issue
Such issues are often caused by bugs in graphics drivers (Blender uses OpenGL selection which partially runs on the GPU) so the first thing you should try is if updating you graphics driver helps. The issue could also be caused by a changed keymap though, so you can try if using factory settings helps ({nav File > Load Factory Settings}). Some more troubleshooting steps are listed here .
Please try these things and report back if the issue got solved or not.
Mrto Select no longer works. Can not select vertex, edge or surfacesThanks for the input.
I solved the problem by stepping back to version 2.77 and "recovering my last session" prior to upgrading. This solved the bug for now. I will try upgrading later after I finish my current project.
Added subscriber: @Blendify
Closing for now then.
