Object Join Bug with multiple instances of same mesh. #49795
2 Participants
Reference: blender/blender#49795
Windows 8.1 nVidia geforce gt 620m intel i3 2328m
2.78
Worked: (I do not know what I answer the right question but) everything else works fine
When I join some trees that were converted (and placed) by an hair particle system to their own objekts,
a lot of new ones appeared arround the others that were joined as their own objekts.
bug.blend
Added subscriber: @SimonRazer
Added subscriber: @mont29
The problem is not related to particles at all, in fact, it happens in any case where a same mesh is instanced by multiple objects - then if you join it with other objects, all instances of the mesh are “considered”.
Don’t think this is intended behavior though (will have to check code to be sure).
Objekt Join Bugto Object Join Bug with multiple instances of same mesh.Changed status from 'Open' to: 'Archived'
Arf… My bad, in fact this totally expected behavior!
When you join several objects into a same mesh, all those objects' geometries get added to active mesh's geometry. If that mesh is instanced multiple times, you obviously get those geometries also multiplied across all instances.
To achieve what you want here, you can e.g. create a temp mesh (even an empty one), and selected it last, such that all other objects get merged into that one.
Or other solution, make single user one of your mesh, and merge all others into that one.
In any case, thanks for the report, but no bug here.
