Cycles Motion Blur + python bpy.context leads to error and VRAM overload #49797
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#49797
Win10, 16Go RAM, gtx 980 6GB
Blender 2.78
SUMMARY:
Very specific nagging bug.
When rendering with cycles motion blur (GPU) enabled and running an addon containing 'bpy.context.active_object' inside a persistent function, blender generates an error and over loads the VRAM, leading to CUDA error: out of memory while rendering.
STEPS:
Set the renderer to Cycles, using the default scene
Install and enable the attached addon : addon_vram_overload.py
Switch to GPU compute and enable Motion Blur
Start rendering 100 frames
Monitor the VRAM usage with GPU-Z for example, or wait until Out of Memory error message appear.
You can check the console: AtributeError 'Context' object has no attribute 'active_object'
Now replace this line in the addon:
ob = bpy.context.active_object
by this one:
print("")
Render the animation again
The VRAM is no more overloaded.
COMMENT:
So yes, the workaround in python would be easy, it's all about avoiding the error:
The problem is it happens on several scripts already used by a lot of users. Is there a way to resolve this memory consumption when this error occurs?
Thanks for your great works!
Added subscriber: @LucasVeber
Added subscriber: @YAFU
This issue was referenced by blender/blender@32c2cba4ef
Thanks Lucas for the clear report and thank Sergey for the fix.
This problem had given me more of a headache with some addons, and some people out there having this problem but without them knowing exactly why.
Thanks!
Thanks for quick fix Sergey!
