difining an operator as text.myoperator doesn't enable setting shortcut from context menu. #49800
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#49800
I have an addon where I used operators with a path text.myoperatorname.
When defining a panel with the buttons, in right-click menu there wasn't the possibility to add shortcut.
when I changed the operator path to object.myoperatorname, shortcuts are enabled.
submitting just the addon in version where it works:
macros.py
this is not working (operators with text.something)
macros_bad.py
Added subscriber: @VilemDuha
Added subscriber: @Sergey
Thanks for the report, but it is not really a bug, but a specific behavior of how keymap matching currently works.
Thing is, when you define your operator as
text.something
it is supposed to be related to text editor context. Keep this in mind.Now, when you right-click on a button Blender will first check whether shortcut is already defined for this operator within the current context, and if so will let you to edit that. This isn't your case yet.
If there is no current shortcut defined for operator yet, it'll try to deduct which exact keymap to add it. In you case because it's
text.something
Blender will suppose that the operator belongs to "Text" keymap. However, there is no "Text" keymap in the 3d viewport context, hence Blender will not be able to create shortcut for your button.There might be some improvements to such guesses be done, but those are happening outside of the bug tracker.
For the time being, will suggest just to stick to a strict context specification rules, which is a good idea anyway.
the addon we are talking about is called Macro.
Basically it runs any internal script from a custom panel like it would be an operator(even with props :) ), so it can not have a specific context...
maybe, the solution is to define the same operator for different contexts? so I have text.run_macro, object.run_macro e.t.c.?
https://blenderartists.org/forum/showthread.php?343029-Macro-script-runner-make-your-operator-prototyping-faster
