Allow syncing edits between DopeSheet views
Closed, InvalidPublicTO DO
I'm making an animated sketch for a short movie using Grease Pencil. I sometimes also animate opacity of some Grease Pencil layers.
The problem is when I need to shuffle some scenes around (cut one chunk of the animation and move it elsewhere) I need to do this twice, becasue if I move my GPencil keyframes, the rest will stay in old places, breaking the animation, so I'd need to switch to another DopeSheet view and pprecisely redo my selecting and moving to keep the animation consistent.
Can't this be done with one move instead of two?
It seems I cannot view both GPencil and the rest of keyframes that make up my animation:
I found there's a way to sync time between all the Dope Sheets and the Timeline (it's called "Lock time to Other Windows"). Could it be possible to also sync edits?
I imagine this would work like this:
  1. You select some keyframes in one Dope Sheet view, and some other in another Dope Sheet View.
  2. You enable "Sync editing" between then
  3. You press "G" and move the keyframes in one DopeSheet view, and the selected keyframes in another synced view follow along like if it all was in one window.
Tobiasz Karoń (unfa) renamed this task from Allow viewing GPencil keyframes in the same Dopesheet view as the rest of the Scene's animation to Allow syncing edits between DopeSheet views.Oct 28 2016, 12:02 PM
Tobiasz Karoń (unfa) updated the task description. (Show Details)
Bastien Montagne (mont29) changed the task status from Unknown Status to Invalid.Oct 28 2016, 3:46 PM
Thanks for the suggestion, but we do not accept feature requests or suggestions on this tracker (use forums or bf-funboard ML for that).
Please do not create design/todo tasks, they are reserved to developers.
