blender crashes when add a inverse kineatics constraint to bone #49899
6 Participants
Reference: blender/blender#49899
when added a inverse kinematics to a bone it causes a crash.
my OS:
windows 7 ultimate x86
processor: amd phenon 9500 quadcore 2.21GH
nvidia geforce 6050SE nforce 430
blender version:
blender 2.78a hash
e8299c8
the bug not is happening in previous versions.
steps
open blender, delete defaut cube and add a single bone, go to edit mode, extrude the bone tree times and duplicate the last bone, unparent it, go to pose mode and add a inferse kinematic constraint setup, uncheck use tail opition, and it will crash blender.
or simply enable auto IK and try editing the pose.
this file crashed blender all times:
console screenshot on exact moment of crash:
crash.blend
https://www.youtube.com/watch?v=yce51lIKgvU&feature=youtu.be
sory my bad english.
Added subscriber: @jeacom
#50033 was marked as duplicate of this issue
blender crashes when add a inverse kineatics constraint is added to boneto blender crashes when add a inverse kineatics constraint to boneAdded subscriber: @Blendify
I could not reproduce maybe an 32-bit thing?
Added subscribers: @Sergey, @LazyDodo
It's a mem alignment issue in bf_intern_iksolver, none of the classes care about their alignment, yet they use eigen which really wants them to be aligned at 16 byte boundaries (for vectorization reasons) , this can be fixed by overriding the class new and delete operators like this
But it feels a little dirty to cut / paste that all over the place? Given this is not the only place in blender plagued by this (ge_phys_bullet ge_converter and bf_intern_libmv emit similar warnings, for at total of 20+ classes in blender that have this issue ), Bullet is by far the worst offender, and in never versions they solved it with a macro like this
http://www.letworyinteractive.com/blendercode/d0/d6b/btScalar_8h.html#a0bd5b84db13a000ac43fffe2bfc32187
Sergey, what's the preferred way of addressing this in blender?
We can have something similar, yes.
Did you check if using aligned attribute on class and/or property helps?
It doesn't, it only really helps for things that are allocated at compile time the docs ( https://msdn.microsoft.com/en-us/library/83ythb65.aspx ) mention
Hrm, so we'll need to do aligned-alloc for those classes. For that doing something what you showed should work (we should be able to use
EIGEN_MAKE_ALIGNED_OPERATOR_NEW
).However, not sure that will be enough. Thing is, even object itself is aligned it doesn't mean its properties are aligned, so guess alignment attribute is still needed?
Judging from https://eigen.tuxfamily.org/dox-devel/group__TopicStructHavingEigenMembers.html the eigen classes have aligned attributes on them, so the structure layout will be aligned at compile time. EIGEN_MAKE_ALIGNED_OPERATOR_NEW makes sure that whenever you new up a class it'll be aligned as well.
Added subscriber: @Almisuifre
Added subscriber: @SergeL
This issue was referenced by
0de157a320
