Recent changes to Cycles device selection broke Auto Tile Size add-on #49959
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#49959
Broken: blender/blender@dd921238d9
Worked: before blender/blender@dd921238d9
This commit blender/blender@dd921238d9 breaks Auto Tile Size device detection code.
Exact steps for others to reproduce the error (UPDATED)
None
toCUDA
CPU
toGPU Compute
Look into console
Where you'll see this error:
Added subscriber: @MikhailRachinskiy
Added subscriber: @dfelinto
I don't see any error here. Please write down the error you get on the console. Also what is your OS, and if any extra step is required to reproduce the error (e.g., open the Performance panel? click settings?)
I am so sorry about that, here is complete steps to reproduce the error:
None
toCUDA
CPU
toGPU Compute
Look into console
I guess if you'll use
OpenCL
instead ofCUDA
it would result in the same error, but I cannot check this.Added subscriber: @VukGardasevic
I can confirm the issue with dd92123 on win 7
The same problem was reported on https://developer.blender.org/D2338#54191
The userpref.system.compute_device_type check needs to be changed.
Changed status from 'Resolved' to: 'Open'
@dfelinto I hope you don't mind that I reopened and updated the task?
Also I can take the assignment if you guys have your hands full.
I have some code that solves the current bug, however the function get_threads will fail too
The number of threads is calculated by splitting the string from the end.
I'm not sure where to look in this case, so any pointers are welcomed.
Added subscribers: @GregZaal, @LukasStockner, @JulianEisel
Add-on errors should preferably be handled by authors, IIRC that was @GregZaal?
Added subscriber: @RainerTrummer
would propose the following fixes:
method engine_is_gpu in line 149:
method get_threads in line 206:
However, only tested on a multi-CUDA-GPU rig, don't have OpenCL devices at hand here
Should be resolved by the commits by Brecht from November 17th:
Changes on the cycles side:
60409841a4b9
Changes in the add-on:
71daaea8cd
Please test the fix by downloading the latest build.
