Can't delete duplicated vertices
Windows 10
Nvidia GeForce GTX970m
Broken: 2.78
When trying to delete duplicated vertices this error appears sometimes. It has happened before with other models/files but I've also been able to do this (deleting duplicated vertices) multiple times, so it doesn't happen with everything, but it is does happen every time with this example.
  1. Select all vertices.
  2. Delete duplicated vertices
  3. Get this:
  File "C:\Users\Erika\AppData\Roaming\Blender Foundation\Blender\2.78\scripts\addons\asset_management_V_1_1_5\ui.py", line 282, in draw
    if len(listdir(favorites_path)):
FileNotFoundError: [WinError 3] The system cannot find the path specified: 'C:\\Users\\Erika\\Google Drive\\CG\\Addons\\Blender\\Favorites'
it seems it's more a problem from asset_management addon, try to disable it a see if the problem is still here.
If it is, make a report for asset_management addon not for blender.
thanks
Oh, sorry, the addon has a Report Bug button and it's the first time I submit one for Blender and the link got me to the submit bug site in here, so I just assumed I should add it as a tag, gonna go put that in the correct place.
Krantz Geoffroy (kgeogeo) closed this task as Resolved.Nov 8 2016, 10:00 PM
Krantz Geoffroy (kgeogeo) claimed this task.
No problem.
