SVG Import scaling is wrong on some files #50048
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#50048
2.78a, e8299c8
SVG files with
viewBox
attribute that differ from with/height attributes are scaled wrong.Exact steps for others to reproduce the error
Cteate SVG file with content below:
And then import it with
File -> Import -> Scalable Vector Graphics (.svg)
. It is expected that the square will be 1x1 Blender units, but it's 3543x3543 Blender units.That is because scaling is performed twice in
SVGMatrixFromNode()
function inimport_svg.py
file.I don't quite understand what's happening during the function and why first scaling is needed, but I've made a "patch" that, I believe, kinda solves the issue. I may be totally wrong with this solution =)
import_svg.diff
Added subscriber: @uvx3
Added subscribers: @Sergey, @VukGardasevic
I did an import on the generated SVG file with the code from the example and the scale seems off.
@Sergey when you have time, can you look into it. Thanks. :)
@uvx3, can you submit diff in an unified format (o even better, diff generated by
git diff
) ?Sorry for the wrong diff format.
Here's an output of
diff -u
.import_svg.diff
It's strange, but I cant attach the python file. Here's a link to the file I've uploaded to github.
Added subscribers: @howardt, @BrendonMurphy
@howardt anything to do here?
@BrendonMurphy, not sure why Howard is involved here. If this is still an issue the patch needs to be updated against latest sources.
@Sergey my mistake, I was looking at his addon in contrib
Removed subscriber: @howardt
@Sergey was this fixed by c2aef4a98f: SVG: Fix wrong closed path with quadratic segments?
@BrendonMurphy, that sounds as an unrelated change, but there were other fixes related to this one, i.e.
b302fdf053
.I've tried to import the demo SVN from this task and it shows as 1x1 plane, which is what the task description says is expected.
So my guess is that everything is working fine now.
Added subscriber: @iss
SVG file is imported as 1x1 plane now so I will assume this has been resolved.
If there are still any issues with scalig, please file new report
