Bmesh booleans fail on simple cube array #50165
7 Participants
Reference: blender/blender#50165
This Bmesh based boolean setup brings wrong results compared to Carve. It's a typical use case from a visualization project.
array.blend
Tested with the official Blender release on Windows 7 64
Some background:
I'm doing architectural visualizations so I often use boolean operations to create flexible and changeable setups of facades in case architects change their minds about a design during the project. When using booleans on a regular basis on complex stuff like me then it is inevitable to recognize that the Bmesh booleans are still inferior to those of Carve. Since I assume that Carve is a library you would like to drop at some point in the future, I would like to express my concerns that this must not happen until Bmesh booleans are at least as reliable as Carve is. This should really be a condition from my point of view as a user, some people have to work with it after all.
Anyways, I have great respect for your work and I'm willing to provide more bug reports on the matter until this target is reached. Consider this only being the first one.
Added subscriber: @KaiKostack-3
Added subscriber: @Ko
Do not hope for a quick solution to this problem. Developer of modelling tools and bmesh has withdrew from active blender development. It could take years before bmesh boolean mode will be corrected by someone else
Then I suggest to change the default method back to Carve until someone will take care of the Bmesh method. In the current state and without active development this is an experimental feature at best.
Added subscriber: @VukGardasevic
BMesh Boolean currently has it's own limitations and failure cases.
To check some of them you can look at the task #47030 that tracked related issues.
Added subscriber: @MarcClintDion
Using 'Carve' fixes the issue. Head over to the Modifier stack and use the Drop-down menu for the Boolean Modifier to change the solver from BMesh to Carve.
Using Carve actually doesn't fix the issue in Bmesh but thanks anyway. ;)
Added subscriber: @Prototype-1
Here's what I've found:
bm_face_split_edgenet_find_connection( ) creates edges that are parallel to other edges. This causes face creation to fail when it sorts the edges by angle.
bm_face_split_edgenet_find_loop_pair( ) fails when multiple boundaries and wires are connected as it gives priority to wires, in some cases it selects edges that cannot form a face.
Additionally I get a failed assert on line 560, the stack 'vert_queue' is overflowing, I'm not sure what the reasoning behind it's declared size is so I didn't change it.
This works for the given case:
P434: Possible fix for #50165
Added subscriber: @ian_bruce
For a much simpler testcase, apparently demonstrating a similar problem -- non-solid objects resulting from boolean intersect with BMesh -- see #51236 . Again, "Carve" produces the correct result, "BMesh" doesn't.
Added subscriber: @ideasman42
@Prototype-1 - thanks for looking into a fix, however this now works in 2.79.
Although the changes in your patch may still be an improvement on the existing logic.
I've uploaded an updated version of your patch at D2844
I'd be interested to find if this fixed any cases that are broken in master.
Note the
bug you ran into has been fixed too1247f609d4
