Ubuntu 16.04 64 bit - Intel graphic card
Broken: Blender 2.78a Official. Hash : e8299c8
Blender crash during weight transfer selecting type "vertex mapping" at options from weight transfer box if the input object not have any face (only vertex)
You can make a workaround easy adding a simple face to the input data object.
There is only two objects at scene:
A ) one with vertex groups and vertex points but no faces
B) one torus without any vertex group.
Then :
Select input info object A
Select B while selecting A (holding Shift) making it parent from selection.
Select weight paint mode
At weight paint tools ("T" panel) , select Transfer Weights
Then from transfer weights dialog, select "vertex Mapping", any option (well I not try every option but brokes with the first ones) . That produce the crash.
You can add one face or more to object A to bypass this problem.
