"Archimesh" problem (looses UV resize on floor and loopcuts) #50236
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#50236
windows 7 64bit , HD graphics 4000
Worked: 2.77
"Archimesh" addon looses (UV scaling and Loopcuts) when you disable and enable again celling
After creating room with 4 walls,floor and celling i do some texturing on floor.Because i am new user ( 1 month old) i hide one wall and celling so its more comfortable to work in room. I edit texture,unwrap it and scale the UV map to fit my floor but when i put celling back for "test rendering" the floor looses all the scale or rotate i did in last step.The same think happens on walls.If i put some loopcuts(for multiply textures) and disable and enable again the celling loopucuts they are not there anymore.
P.S. as i said im very new user so i apologize if this is something i do wrong!!
BugScene.blend
Added subscriber: @GiorgosMakropoulos
Added subscriber: @antoniov
I think this is not a bug, but a missunderstanding of how the add-on works.
When you change something of the room using the parameter panels, all the mesh is recreated, so if you have done some adjust or change manually, you will miss your work.
In order to keep your work, first design the room with all walls and dimensions, and then work in the UVs or any other custom modification you want to add, but remember, if you change a parameter, you will miss your custom changes.
As this is not bug, we can close it.
