Cycles: difference in texture position between OpenGL and Cycles render (CPU and OpenCL) #50238
6 Participants
Reference: blender/blender#50238
all vendors
Broken:
2bb7a13
Texture position is different in viewport material viewmode and rendered viewport
Open attached blend bug tex proj geom opencl openGL v2.blend, hit shift+Z in viewport to start border rendering. You get a visible position difference:
Added subscriber: @matali23
Added subscribers: @LukasStockner, @MartijnBerger, @Sergey, @ThomasDinges, @mont29
Can confirm, probably some OGL code not inline with actual render? @Sergey, @ThomasDinges, @LukasStockner, @MartijnBerger or any other #Cycles dev interested? ;)
Added subscriber: @bliblubli
Can also confirm. I encountered the same bug today. After double checking, the OGL size and/or position is wrong, the cycles size and/or position is right.
it's the math divide node that trigger the bug: bug glsl position tex1.blend
Interesting!
If i re-type that 0.008 then the issue goes away. How did you put value to the node?
Added subscriber: @fclem
Here is a simpler file.
bug tex proj geom opencl openGL v2 (1).blend
Increase the rotation Z value with shift click and you will see it only updates after a view click. In render mode it updated right away.
This is a precision issue.
The object is far from the rotation origin and the value on which you apply the rotation is very high / low.
I guess OGL has less float precision when dealling with this. It seems that all transformation are baked into a single matrix on the GLSL end. I do not know about cycles.
Mapping node is converted to mat4 on CPU side for both GLSL and Cycles. Shading system will perform point*matrix multiplication when evaluating shader.
There might be some precision loss there because we use different code on Blender and Cycles side to construct matrix (aka, we don't access matrix from Cycles via API but recontruct it).
Same here, retyping the value removes the bug :D I copy pasted it from the original attached file I think.
@fclem Not sure, but if it was a precision issue, retyping it wouldn't solve the bug?
Ok, another precision. Python doesn't suffer from this problem. So replacing the divide node at 0.0084667 with a multiply node at 1/0.0084667 workaround the bug. But it's really cumbersome. This view is at 39 unit from origin. I wouldn't call that far away, so precision shouldn't be an issue. Maybe constant folding could do this job and change the divide node to a multiply node? Or just rearrange computation to maximize precision?
This issue was referenced by
467d824f80
