RenderEngine - use of python threads with sleep(0)/wait(0) crash #50308
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#50308
Windows 7/x64, W8100
Broken: 2.78a, e8299c8
Worked: 2.77a
Usage of time.sleep(0)/Event.wait(0) with a RenderEngine leads to crash
Load the test addon from addon.7z . Enable 'Test' RenderEngine. Repeat pressing Shift-Z in a View3D twice(to enable RENDERED mode and to turn if off). Blender crashes(eventually, for me it's very often immediately after second Shift-Z).
Cause of this - is use of time.sleep(0) within the thread proc. Changing '0' to even '0.000001' seems to prevent crash.
Crash message varies, could be
or
Added subscriber: @KerimBorchaev
Added subscriber: @mont29
Not sure to understand the point of using
sleep(0)
… In any case, this totally looks like python issue to me, Blender does absolutely not interact with low-level modules liketime
orthread
.Not sure what to do anyway, unless you can show us that Blender is responsible for that. Did you try doing that in exact same python directly (without using Blender's interpreter)?
It is crashing immediately after RENDERED mode is turned off. No addon code is executed on this event - therefore it's something in Blender?
Sure, threads with sleep(0) works fine in pure python.
Doesn't matter for me, personally, as anything non-zero passed to sleep seemingly fixes the issue.
But there's something wrong, this code should not crash.
Added subscriber: @Chipe1
Added subscriber: @Sergey
Bisection shows that crash appears in blender/blender@0cc514ec84. @Sergey, Maybe something missing in new toggle code?
This is not related to my change actually, but rather specific to how threading works in Python.
Basically, before my change the shading mode was changing via python script, so it was a stacktrace like:
From the C side we do use
BPy_BEGIN_ALLOW_THREADS
/BPy_END_ALLOW_THREADS
to ensure we don't run into threading issues with render engine API. This works fine for Cycles (which doesn't use Python threads), but gives issues in this particular case. Seems call ofBPy_BEGIN_ALLOW_THREADS
causes race condition with the thread which is still spinning from the python side.Those begin/end blocks were added in blender/blender@5036ac6. Not yet sure whether it's specific to our
BPY_thread_save()
/BPY_thread_restore()
implementation or not.With the old code it was still possible to crash blender by changing shading using menu instead of the shortcut.
Looks like python threads are just doomed to crash when Shading mode is toggled. It's not just about sleep/wait.
E.g. replacing
sleep(0)
in the example code with simplewith lock: pass
makes it crash immediately on second Shift-Z.Is there a possible workaround? Does addon code have any chance to shutdown it's threads before shading mode is toggled? Or defer the toggle so it doesn't happens immediately when Shift-Z is pressed?
Hmpff… the main issue is that using python threads inside of Blender is risky at best, it’s only reasonably safe when py threads are fully outside of Blender context (i.e. do not use Blender data, do not call Blender API, are not called by Blender, etc.). I think the issue here is that renderengine callabacks can be called from a job, i.e. from non-main Blender thread, if that’s the case those callbacks should definitively never use any python threading.
Further more, due to main lock in python, pythreads are usually not interesting for performances-driven parallelization, one should rather use processes for that.
Am tempted to consider this as known limitation for now, do you have any reason to actually use pythreads here, and not e.g. concurrent.future with a process pool? On the other hand, if you only want some kind of async update, then I would recommend looking at asyncio, even though its usage remains a bit dodgy in Blender currently…
Yes, I'm aware that Blender context should not be used in a thread. But my examples I think are completely avoiding it. If I'm not mistaken ;)
The reason we are using python threads - is convenience. We have a third-party dll that has rendering capabilities and thread is essentially needed to call a (blocking) 'render' function asynchronously. Your guess is right. This requires a thread. Everything else - is suboptimal. Native thread will add substantial complexity(C++ code), same with interprocess communication. And asyncio won't help - threads will need to be used there too for a blocking task(which we have here).
Worked fine in 2.77!!! From my perspective)
Are you saying that the problem might be that the thread is started from an engine callback?
Is it a viable workaround then - call a custom operator while in
view_update
and start that thread from the operator'sexecute
?Seems like ANY python thread might crash when RENDERED is being turned off. In my test I've simply added an operator that spawns a thread. Not using a renderengine callback(callbacks are empty). It crashes.
addon_thread_from_operator_crashes_on_rendered_off.7z Just execute the 'Test Start Thread' operator and start pressing Shift-Z(using Test engine or Blender doesn't matter) - it crashes after a few iterations.
Here is some conclusion here:
Surely supporting more cases will be cool, but Blender is not a framework and such tasks gets really low priority. Would also be nice to have help figuring the threading issues from the guys who actually use such threads.
For until then considering this a TODO.
