Debian Wheezy kernel 3.2.0-4-amd64
and Debian Jessie kernel 3.16.0-4-amd64
Broken: 2.78a
Worked: 2.77a
Blender crashes when trying to add a texture node to the composite nodes.
- Launch Blender
- Go to Compositing Screen
- Check "Use Nodes" Option on the Node editor Window
- Press Shift + A > Input > Texture. Blender crashes.
It works properly if you follow these steps:
- Launch Blender
- Check "Use Nodes" Option on the Node editor window
- Uncheck "Use Nodes" Option on the Node editor window
- Place the texture node in the Node editor window with LMB.
