blf.dimensions reports different text sizes with Region Overlap enabled, 3D View shown, and panels set #50372
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#50372
We have found that
blf.dimensions
returns different text sizes (by ~10%) if Region Overlap is enabled and the 3D View is particularly configured.To replicate:
Enable Region Overlap in User Prefs > System
Set main window to have 3D View and Python Console (other areas seem not to matter)
3D View: Tool Shelf closed, Properties Panel closed
In Python Console:
>>> import blf
>>> blf.dimensions(0, "test")
(19.3125, 7.875)
3D View: open Tool Shelf
In Python Console
(21.703125, 8.59375)
Anything but Region Overlap enabled + Tool Shelf opened + Properties Panel closed, and
reports(19.3125, 7.875)
. Strangely, in Retopoflow, we found that the issue shows up when Region Overlap is enabled and Properties Panel is opened (Tool Shelf does not matter). (see https://github.com/CGCookie/retopoflow/issues/88 for results) Also, the issue does not appear if 3D View is not shown (switch to Text Editor, for ex).Tested in fresh install of Blender 2.78a on OSX and Linux, but it seems that we've had this issue since Jan 2015.
Added subscriber: @gfxcoder
Added subscriber: @JonathanWilliamson
Added subscriber: @mont29
There is no bug here actually, this is just a matter of font size.
When Properties of 3DView is shown, last size used during text drawing for default font is
11
, while it’s12
when props are hidden.Note that you cannot do much about this in python console, since redraw happens between each line of code, but in a 'real' script you shall call
blf.size(0, 11, 72)
(size 11, dpi 72) or whatever size/dpi value you need prior to computing size of the text.Anyway, no bug here really.
Thanks, @mont29! That solved the problem!
Seems we were calling
blf.size()
, but only after callingblf.dimensions()
and before drawing the text, so the text drew correctly.
