Cycles cull option ui problem #50460
5 Participants
Reference: blender/blender#50460
ubuntu 16.04, 630gt
Broken: master
0a446d7
if the option "use camera cull" is active in the simplify panel the per object (use camera cull) setting is grayed out and if the "use distance cull" is active both per object options are active
that would work https://hastebin.com/odoyelozej.vbs
Added subscriber: @nudelZ
Added subscriber: @VukGardasevic
The behavior of
.active
with rows that share the same parent can be an issue that can show up elsewhere in the UI, so adding user interface tag too.If it is an expected behavior, it probably needs documenting the proper usage in this case.
Possibly
.disabled
acts similarly too.Added subscriber: @dfelinto
Thomas, care to look at it?
I don't see how this is an underlying issue with the layout engine. Using a .active or .disabled tag, assigned to a certain layout block will affect all of its assigned properties. So using two different UI blocks is a proper fix.
Will commit a fix based on Ronnys suggestion.
This issue was referenced by blender/cycles@72abe48a66
ff1b850081
I do understand but:
.alert
behaves differently (it's capable of marking individual entries of children)development_icons_get.py
add-on)To show the point this is the modified code from D2464.
Using
alert
:Workarond for
.active
:Anyway, this could be a Topic for 2.8 and it is probably outside of the scope of this task.
