Image Preview for Scene strips in the Video Sequence Editor doesn't update accurately when Scenes use Linked Libraries #50578
Reference: blender/blender#50578
Windows 7 x64
NVIDIA GeForce GTX 580
Broken: 2.78a
e8299c8
sequencer_bug.blend
sequencer_bug_lib.blend
Place the attached .blends in the same folder, open sequencer_bug.blend and try slowly scrubbing the playhead backward and forward. If the Image Preview doesn't update as expected, press CTRL+Z and try scrubbing again to induce the bug. Switch the Screen Layout to Default to see how the Scenes are set up.
Usually, as you scrub the playhead along the first Scene strip the Image Preview will behave as expected, but when the playhead gets to the second Scene strip the Image Preview may not update. Depending on where the playhead rests, when you execute the Refresh Sequencer operator there will either be no change or a frame from the wrong Scene may appear in the Image Preview. Strangely, if you CTRL+Z to undo the Refresh Sequencer operator or the last playhead scrub, the Image Preview may jump into place. However, when you subsequently scrub the playhead the Image Preview will begin to behave even more erratically, jumping between different incorrect frames belonging to both Scene strips' Scene timelines.
The links of Datablocks between the two Scenes, the current_frame of each Scene, the Scene strips' Channel arrangement or their Use Sequence and Camera Override properties don't seem to make a difference. Everything seems to behave properly when all Datablocks are local and not linked.
Added subscriber: @bunny
Added subscriber: @Blendify
I could not reproduce please try with a nightly build from https://builder.blender.org/download/ this sounds familiar so it may have been fixed already.
Was able to reproduce this bug in the nightly build
3ab8895
.However, so far I find that I'm unable to reproduce the bug using the old depsgraph in either build. I always start Blender with the new depsgraph enabled in order to avoid dependency cycles when using constraints while animating.
It looks like this error only occurs when using the new depsgraph, even if there are no constraints in any Scene, and without any feedback in the console.
Thanks for the information
This is caused by the way how on_visible_update() function works for the new dependency graph. This is fully changed in blender2.8 now, and i still under process of redesign.
So thanks for the report, but it's more a TODO about ongoing redesign process we do in 2.8 branch.
