File Browser open to slowly
Closed, InvalidPublic
Windows 10 pro
2.78a
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Feb 6 2017, 8:04 AM
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Please seek user support on user forums like blenderartists.org or blender.stackexchange.com.
Note that things like slow network 'drives' or old floppy disks, or even cdrom, can make filemanager slow on Windows, due to how that OS handles queries on file system.
The same problem are the versions 2.75, 2.74.
The version 2.73 us older do not have it!
as from the other discussion from the other forum, i grabbed some additional information:
System Information:
Windows 10 Pro x64
Blender Version:
Broken: blender 2.78a, da08aa4, 2.75, 2.74
Worked: blender 2.72, 2.73
Short description of error:
File Browser open too slowly
difference between blender <=2.73 and blender >=2.74 are about 15 seconds.
Exact steps for others to reproduce the error:
Texture> Image or Movie> Image> Open
information grabbed from https://www.blendpolis.de/viewtopic.php?f=14&t=54648
well, is it a win10-only issue then? also, again, do you have some kind of special drives (network ones, floppy, cd-rom)? and does this only happens when opening a picture? or any kind of filebrowser?
The problem is with me with Windows 10 pro and only from the version 2.74 and the newer ones. The version 2.72 and 2.73 does not have the problem. I have already made many attempts. I have also reinstated the Windows 10 and the problem was there.
Whether I have these bitmaps on the main disk or external disk, the problem is there.
The delay (almost 15 seconds) is at: Texture> Image or Movie> open
In the File Browser, is the recursion set to something else than None?
Do you have any add-ons enabled?
Can you try the latest build and attach the generated system-info.txt by dragging and dropping it into the comment field? (avoid copy/paste directly of the text)
The software is installed and not changed.
Blender 2.78 (sub 0) System Information
Blender:
version: 2.78 (sub 0), branch: master, commit date: 2016-10-24 12:20, hash: e8299c8, type:
build date: Mon 10/24/2016, 09:31 AM
platform: Windows
binary path: 'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\blender.exe'
build cflags: /W3 /w34062 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /we4013 /we4431 /DWIN32 /D_WINDOWS /W3 /nologo /J /Gd /MP /openmp
build cxxflags: /W3 /w34062 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /we4013 /we4431 /DWIN32 /D_WINDOWS /W3 /GR /EHsc /nologo /J /Gd /MP /EHsc /openmp
build linkflags: /MACHINE:X64 /OPT:NOREF /SUBSYSTEM:CONSOLE /STACK:2097152 /INCREMENTAL:NO /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib /ignore:4049 /ignore:4217 /ignore:4221
build system: CMake
Python:
version: 3.5.1 (default, Feb 17 2016, 17:09:19) [MSC v.1800 64 bit (AMD64)]
paths:
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\scripts\\addons_contrib'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\scripts\\addons'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\scripts\\startup'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\scripts\\modules'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\python35.zip'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\python\\DLLs'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\python\\lib'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\python'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\python\\lib\\site-packages'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\scripts\\freestyle\\modules'
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\scripts\\addons\\modules'
'C:\\Users\\jkott\\AppData\\Roaming\\Blender Foundation\\Blender\\2.78\\scripts\\addons\\modules'
Python (External Binary):
binary path: 'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\python\\bin\\python.EXE'
version: Python 3.5.1
Directories:
scripts:
'C:\\Users\\jkott\\Downloads\\blender-2.78a-windows64\\blender-2.78a-windows64\\2.78\\scripts'
user scripts: 'C:\\Users\\jkott\\AppData\\Roaming\\Blender Foundation\\Blender\\2.78\\scripts'
pref scripts: None
datafiles: 'C:\\Users\\jkott\\AppData\\Roaming\\Blender Foundation\\Blender\\2.78\\datafiles\\'
config: 'C:\\Users\\jkott\\AppData\\Roaming\\Blender Foundation\\Blender\\2.78\\config\\'
scripts : 'C:\\Users\\jkott\\AppData\\Roaming\\Blender Foundation\\Blender\\2.78\\scripts\\'
autosave: 'C:\\Users\\jkott\\AppData\\Roaming\\Blender Foundation\\Blender\\2.78\\autosave\\'
tempdir: 'C:\\Users\\jkott\\AppData\\Local\\Temp\\blender_a02564\\'
FFmpeg:
avcodec: '55, 39, 101'
avdevice: '55, 5, 100'
avformat: '55, 19, 104'
avutil: '52, 48, 101'
swscale: ' 2, 5, 101'
SDL:
Version: 2.0.4
Loading method: linked (WITH_SDL_DYNLOAD=OFF)
Other Libraries:
OpenColorIO: 1, 0, 8
OpenImageIO: 1, 6, 9
OpenShadingLanguage: 1, 7, 3
OpenVDB: 3, 1, 0
Alembic: 1, 6, 0
OpenGL:
renderer: 'Quadro FX 1800/PCIe/SSE2'
vendor: 'NVIDIA Corporation'
version: '3.3.0'
extensions:
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_clear_buffer_object
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_bit_encoding
GL_ARB_shader_objects
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirror_clamp_to_edge
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_stencil8
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXTX_framebuffer_mixed_formats
GL_EXT_Cg_shader
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_import_sync_object
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_debug
GL_KTX_buffer_region
GL_NVX_conditional_render
GL_NVX_gpu_memory_info
GL_NV_ES1_1_compatibility
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_explicit_multisample
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_program
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_half_float
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_shader_buffer_load
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_expand_normal
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_S3_s3tc
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control
Implementation Dependent OpenGL Limits:
Maximum Fixed Function Texture Units: 4
Maximum DrawElements Vertices: 1048576
Maximum DrawElements Indices: 1048576
GLSL:
Maximum Varying Floats: 60
Maximum Vertex Attributes: 16
Maximum Vertex Uniform Components: 4096
Maximum Fragment Uniform Components: 4096
Maximum Vertex Image Units: 32
Maximum Fragment Image Units: 32
Maximum Pipeline Image Units: 96
Cycles:
CPU device capabilities: SSE2 SSE3 SSE41
CUDA device capabilities:
Quadro FX 1800
		CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_BLOCK			512
		CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_X			512
		CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_Y			512
		CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_Z			64
		CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_X			65535
		CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_Y			65535
		CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_Z			1
		CU_DEVICE_ATTRIBUTE_MAX_SHARED_MEMORY_PER_BLOCK			16384
		CU_DEVICE_ATTRIBUTE_SHARED_MEMORY_PER_BLOCK			16384
		CU_DEVICE_ATTRIBUTE_TOTAL_CONSTANT_MEMORY			65536
		CU_DEVICE_ATTRIBUTE_WARP_SIZE			32
		CU_DEVICE_ATTRIBUTE_MAX_PITCH			2147483647
		CU_DEVICE_ATTRIBUTE_MAX_REGISTERS_PER_BLOCK			8192
		CU_DEVICE_ATTRIBUTE_REGISTERS_PER_BLOCK			8192
		CU_DEVICE_ATTRIBUTE_CLOCK_RATE			1375000
		CU_DEVICE_ATTRIBUTE_TEXTURE_ALIGNMENT			256
		CU_DEVICE_ATTRIBUTE_GPU_OVERLAP			1
		CU_DEVICE_ATTRIBUTE_MULTIPROCESSOR_COUNT			8
		CU_DEVICE_ATTRIBUTE_KERNEL_EXEC_TIMEOUT			1
		CU_DEVICE_ATTRIBUTE_INTEGRATED			0
		CU_DEVICE_ATTRIBUTE_CAN_MAP_HOST_MEMORY			1
		CU_DEVICE_ATTRIBUTE_COMPUTE_MODE			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_WIDTH			65536
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_HEIGHT			32768
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_WIDTH			2048
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_HEIGHT			2048
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_DEPTH			2048
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_HEIGHT			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_LAYERS			512
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_HEIGHT			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_NUMSLICES			512
		CU_DEVICE_ATTRIBUTE_SURFACE_ALIGNMENT			256
		CU_DEVICE_ATTRIBUTE_CONCURRENT_KERNELS			0
		CU_DEVICE_ATTRIBUTE_ECC_ENABLED			0
		CU_DEVICE_ATTRIBUTE_TCC_DRIVER			0
		CU_DEVICE_ATTRIBUTE_MEMORY_CLOCK_RATE			800000
		CU_DEVICE_ATTRIBUTE_GLOBAL_MEMORY_BUS_WIDTH			192
		CU_DEVICE_ATTRIBUTE_L2_CACHE_SIZE			0
		CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_MULTIPROCESSOR			768
		CU_DEVICE_ATTRIBUTE_ASYNC_ENGINE_COUNT			1
		CU_DEVICE_ATTRIBUTE_UNIFIED_ADDRESSING			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LAYERED_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LAYERED_LAYERS			512
		CU_DEVICE_ATTRIBUTE_CAN_TEX2D_GATHER			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_GATHER_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_GATHER_HEIGHT			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_WIDTH_ALTERNATE			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_HEIGHT_ALTERNATE			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_DEPTH_ALTERNATE			0
		CU_DEVICE_ATTRIBUTE_TEXTURE_PITCH_ALIGNMENT			32
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_LAYERED_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_LAYERED_LAYERS			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_WIDTH			4096
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_WIDTH			4096
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_HEIGHT			65536
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_HEIGHT			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_DEPTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_LAYERED_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_LAYERED_LAYERS			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_HEIGHT			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_LAYERS			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_LAYERED_WIDTH			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_LAYERED_LAYERS			0
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LINEAR_WIDTH			134217728
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_WIDTH			65000
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_HEIGHT			65000
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_PITCH			1048544
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_MIPMAPPED_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_MIPMAPPED_HEIGHT			8192
		CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MAJOR			1
		CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MINOR			1
		CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_MIPMAPPED_WIDTH			8192
		CU_DEVICE_ATTRIBUTE_STREAM_PRIORITIES_SUPPORTED			0
		CU_DEVICE_ATTRIBUTE_GLOBAL_L1_CACHE_SUPPORTED			0
		CU_DEVICE_ATTRIBUTE_LOCAL_L1_CACHE_SUPPORTED			0
		CU_DEVICE_ATTRIBUTE_MAX_SHARED_MEMORY_PER_MULTIPROCESSOR			16384
		CU_DEVICE_ATTRIBUTE_MAX_REGISTERS_PER_MULTIPROCESSOR			8192
		CU_DEVICE_ATTRIBUTE_MANAGED_MEMORY			0
		CU_DEVICE_ATTRIBUTE_MULTI_GPU_BOARD			0
		CU_DEVICE_ATTRIBUTE_MULTI_GPU_BOARD_GROUP_ID			0
I wonder what part of this sentence you did not understand? pasting walls of text like that just make reports painful to handle and follow.
I’d also appreciate you to answer all the questions, afaikt this one still remains unanswered?
Now, another thing to check, do you have any remote/external/whatever non usual folders listed in your bookmarks or recent folder lists (side panel of the browser)? I think that on windows, when we query for the validity of those, OS has to wait for the device to wake up before returning the call, which can generate painful delays for the user... :/
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
