Move "Remove Doubles" command from "Vertices" to "Clean up" submenu
Closed, ResolvedPublicDESIGN
A little low-priority proposal, perhaps to be discussed, about functionality/logical-organization/task-orientation of the UI.
I suggest to move the "Remove Doubles" command from "Mesh>Vertices" to "Mesh>Clean up" submenu (Edit Mode) and perhaps rename as "Remove Double Vertices".
It seem more an "optimize/clean" tool, where "Vertices" submenu seem to be oriented more to "editing/modify" tasks.
blend-it (blend-it) created this object with edit policy "All Users".
This comment was removed by blend-it (blend-it).
Aaron Carlisle (Blendify) lowered the priority of this task from 90 to Normal.
