Blender 2.71-2.7x Laggy Interface/Poor Performance #50670
Closed
opened 2017-02-13 13:41:16 +01:00 by Carlos · 13 comments
I have a windows computer
My processor is an Intel (R) Core (TM) i74710HQ CPU @ 2.50GHz
I have 16 GB of ram and Nvidia GEFORCE GTX 870M
Broken: Blender 2.74-2.7x
Worked: Blender 2.70
I am a Minecraft GFX Designer and when I started to use blender 2.78, everything was working perfectly fine. Running smooth and works well. Then, I heard of Timy's rig that allows me to do Minecraft GFX and I found out that blender 2.78 does not work. I went to the old downloads website and downloaded blender 2.70. Later, the version was too old for some addons that I needed and then when I downloaded blender 2.75, everything was laggy. There were just 5 seconds delays. I found a solution by right-clicking blender and run with integrated graphics. Which seems to have fixed the problem but it is still laggy. I tried almost everything I can do to fix this issue and it does not look like that many people are experiencing the same issue that I am facing. I uninstalled the program and installed it countless times. Restarting my PC does nothing.
I just start up my blender and it lags as heck.
PLEASE HELP ME!!!
**System Information** I have a windows computer My processor is an Intel (R) Core (TM) i74710HQ CPU @ 2.50GHz I have 16 GB of ram and Nvidia GEFORCE GTX 870M **Blender Version** Broken: Blender 2.74-2.7x Worked: Blender 2.70 I am a Minecraft GFX Designer and when I started to use blender 2.78, everything was working perfectly fine. Running smooth and works well. Then, I heard of Timy's rig that allows me to do Minecraft GFX and I found out that blender 2.78 does not work. I went to the old downloads website and downloaded blender 2.70. Later, the version was too old for some addons that I needed and then when I downloaded blender 2.75, everything was laggy. There were just 5 seconds delays. I found a solution by right-clicking blender and run with integrated graphics. Which seems to have fixed the problem but it is still laggy. I tried almost everything I can do to fix this issue and it does not look like that many people are experiencing the same issue that I am facing. I uninstalled the program and installed it countless times. Restarting my PC does nothing. I just start up my blender and it lags as heck. PLEASE HELP ME!!!
Author
Author
Added subscriber: @CyclesCycle
Added subscriber: @mib2berlin
Hi, it seams lag is result of auto update display driver on Windows.
More info:
https://blenderartists.org/forum/showthread.php?415837-Blender-2-76-suddenly-very-slow
Cheers, mib
Hi, it seams lag is result of auto update display driver on Windows. More info: https://blenderartists.org/forum/showthread.php?415837-Blender-2-76-suddenly-very-slow Cheers, mib
Added subscriber: @SandraSmith
If you have side-by-side GPU's, switch to your integrated graphics, and performance will be restored. That's a workaround; I'd be grateful for a solution, because I have the same problem.
Author
Yes, I know that the integrated graphics is the solution but for some reason I see in brackets default. When I open it with that as default, it still has the same issue. When I run blender with the integrated graphics by physically right clicking it and click run with graphics, it works fine. Do you always run blender with that extra right click?
> In #50670#417289, @SandraSmith wrote: > If you have side-by-side GPU's, switch to your integrated graphics, and performance will be restored. That's a workaround; I'd be grateful for a solution, because I have the same problem. Yes, I know that the integrated graphics is the solution but for some reason I see in brackets default. When I open it with that as default, it still has the same issue. When I run blender with the integrated graphics by physically right clicking it and click run with graphics, it works fine. Do you always run blender with that extra right click?
Nope. Never did until the driver changed on the 10th. Now I invoke Blender from the taskbar, where the default is set to use NVidia, and if the program is laggy I close out and invoke it again from the desktop icon with a right-click so I can select the integrated GPU and get to work. That's how I've been informally testing to see whether the problem has been resolved.
If it's the responsibility of us end users to throw rocks at the window until the problem gets noticed by the appropriate people, then I would be grateful if someone would give us directions to the right window.
Nope. Never did until the driver changed on the 10th. Now I invoke Blender from the taskbar, where the default is set to use NVidia, and if the program is laggy I close out and invoke it again from the desktop icon with a right-click so I can select the integrated GPU and get to work. That's how I've been informally testing to see whether the problem has been resolved. If it's the responsibility of us end users to throw rocks at the window until the problem gets noticed by the appropriate people, then I would be grateful if someone would give us directions to the right window.
Oh, I forgot to answer your other question. To set NVidia as the default, you have to go into the NVidia control panel (right click anywhere on desktop) and select ""Manage 3D settings" from the panel on the left. From there you can specify which programs you want to always run under the NVidia GPU.
Added subscriber: @mont29
Please do not set priority of tasks yourself, especially not to high priorities!
And please search for similar reports before creating new ones.
Please do not set priority of tasks yourself, especially not to high priorities! And please search for similar reports before creating new ones.
And please do not change editing policy either!
Bastien Montagne self-assigned this 2017-02-16 14:39:57 +01:00
Closed as duplicate of #50650
Reference: blender/blender#50670
