Boolean modifier in bmesh solver creates random verts
win 10, gtx 1070
Broken: 2.78.4 Hash: 5552e83)
sometimes when cut with boolean modifier with solver set to bmesh(never happen in carve) it create random verts
that creates problems if not noticed since other modifiers can fail
here are to objects with boolean modifier
and her is how mesh looks like after ( one extra mesh was created
apply modifier in added file
Bastien Montagne (mont29) triaged this task as Confirmed priority.Mar 1 2017, 9:49 AM
Here, Error is only seen in when i run the attached file. I am not getting how to produce the error in general. I have tried lots of mesh but there is no extra mesh! Can you plese elaborate, the step done to create the mesh.
Hey Raja,
I think ts important to know that it usually add stuff\fail on cutting flat surfaces. At least from my experience.
here are steps to reproduce
add cube -> bevel one edge -> add 2nd cube -> scale it and rotate by 45->applyboolean modifier to first one -> use 2nd one to diff boolean into first one
gif
and for more complex one
add cube -> sub divide it few times|-> add new cube -> boolean it in the middle -> boolean again (now it will fail)
gif
I got the problem. I am currently looking for the solution in code. For time being, you can manually select the extra vertices and press Ctrl + X to merge it in Edge. for first scenario. For second case, It will look into details.
In 2.78 I can redo this, but I can't redo this in 2.79 or master e360d003ea45ee233c6f10c03ff57c956929b383
Seems this can be closed?
Campbell Barton (campbellbarton) lowered the priority of this task from Confirmed to Incomplete.Oct 9 2017, 4:24 AM
Bastien Montagne (mont29) closed this task as Resolved.Oct 31 2017, 3:58 PM
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
