FBX export saves wrong keyframe values #50684
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#50684
Windows 10
GTX 1080 (x2)
Broken: 2.78 4bb1e22
I'm trying to export baked camera animation to an FBX file to bring into another compositing program. When I import the FBX file (or even re-import into Blender), I noticed the rotation values aren't exactly the same. This makes very noticeable issues when you're trying to match projection mapped geometry to pre-rendered footage.
For example, a key frame with rotation values (92.259, 0.087, 23.025) exports to (92.229, 0.099, 22.706). I'm using XYZ Euler rotations.
baked_camera_animation.blend
Added subscriber: @wayland
After some more research it appears that Blender's FBX exporter has a long history of rotation issues. Something interesting I didn't really mention above is the exported keyframes seem to start off okay - the first 50 or so frames are pretty much spot on. Then it appears to deviate along the vertical axis a bit (shifting the camera left or right by fractions of a degree), but return to expected values after about 30 frames. This happens on and off throughout the animation.
I took a peek at the exporter's source code and I noticed it converts between radians and degrees at various points. Is it possible this is a precision error when rotating/converting the matrix?
"/source/blender/python/matutils/mathutils_Matrix.c" uses a double for the angle value to avoid exactly this problem (see PyObject *C_Matrix_Rotation on line 467), but is it possible something else is creating a margin for error?
Added subscriber: @mont29
I would not expect floating point precision issues to be sensible here.
More likely, you are suffering from the simplification over baked curves applied by default by the exporter (to reduce amount of data and hence size of FBX file).
In the
Animation
settings of FBX exporter, can you please try to set theSimplify
value to zero (and ensureSampling Rate
is at its default value of 1 frame), and see whether this fixes your issue?Otherwise, I’ll need a simple .blend file demonstrating the issue to investigate it.
Well look at that, you learn something new everyday. I completely missed the simplify function - that's exactly what was happening. I agree with you, when I looked at the source code it seemed pretty unlikely it was a precision error but ya never know sometimes.
Move along, there's no bug to see here. :)
Cool, thanks for quick head-up :)
