Weird mesh/bone shifting problem with animation exported to .fbx for Unity #50686
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#50686
Windows 10 64-bit
GTX 1080
Broken: 2.78a
When I export a .fbx to Unity of an animation I'm working on, I get a weird shifting of the facial features of the character.
Not sure what's happening as this doesn't happen in Blender. Is this a bug in the exporter?
Added subscriber: @0o00o0oo
Oopse, forgot to attach the file: FBXexport_FaceShiftProblem.blend
Added subscriber: @mont29
Most likely the same 'issue' as in #50684…
You are probably suffering from the simplification over baked curves applied by default by the exporter (to reduce amount of data and hence size of FBX file).
In the Animation settings of FBX exporter, can you please try to set the Simplify value to zero (and ensure Sampling Rate is at its default value of 1 frame), and see whether this fixes your issue?
I tried it but it's still shifting. =/
I seem to be able to fix the problem by readjusting the hierarchy in Unity, such as moving the "DEF-spine.006" and its child to under "head", "DEF-spine.004" and "DEF-spine.005" to under "neck", "DEF-spine.003" to "MCH-spine.003", "DEF-spine.002" to "MCH-spine.002".
But I'm guessing I shouldn't have to do this if exporting is working correctly.
BTW, in case this helps, the rig is a modified pitchipoy rig where I didn't use its default facial bones in the metarig to generate the facial controls.
I deleted the facial bones and after generating the rig, I created my own facial bones/controls, joined them to the pitchipoy rig, then parented them to the "head" bone.
Oh, and just in case it's needed, before I change the items in the hierarchy, this is the structure as it imports into Unity by default from the .fbx exported out of Blender:
Thing is, I can’t see anything wring when re-importing into Blender. So that could be an issue from Unity side too, did you try to re-import your FBX into Blender and see whether those glitches are visible?
Also, what are you using exactly as animation & armature export settings? did you try tweaking those to see whether it could fix the problem?
I tried reimporting the .fbx to Blender, and as you said, it works fine. Then I tried importing it into Sketchfab and also Unreal Engine and the animations all work fine in those as well.
I also tried exporting from Blender with various options but I can't find a setting that works to correctly import into Unity.
Then would it be safe to conclude it's Unity's import function somehow messing it up?
It might be Unity bug, yes - but it might also be Unity applying some simplifications to animation curves when importing from FBX?
In any case, thanks for the report, but I think that since other tools are able to import the FBX correctly, we can consider there is no Blender bug here.
Added subscriber: @moosefetcher
I realise this is an old thread, but I recently fixed a similar problem by unchecking the 'resample curves' box on the animation tab of the imported fbx mesh. I read it was caused when, in Blender, the animation uses Euler rotations. With the 'resample curves' box checked, Unity converts to Quaternion and it can mess things up, apparently. Probably a little late to help with your problem though...
