crashes on load (2.78b) (EXCEPTION_ACCESS_VIOLATION) #50697
Reference: blender/blender#50697
Win 7 64bit, 6GB RAM
ATI Mobility Radeon HD 5650 (3703 MB RAM)
HP Pavilion laptop
Broken: 2.78b hash
3c04373
Win64bitWorked: 2.78a
Crashes on launch of blender.exe (EXCEPTION_ACCESS_VIOLATION)
Dbl click on blender.exe desktop icon, program starts, displays cmd window, then crashes (never see UI/splash).
I tried using --factory-startup, and the opengl32.dll-in-blender-folder-trick, no luck. I suspect its a video driver problem - I can't get recent drivers for my older laptop (2011?). Using 2.78a version mostly works - it starts up and I can create new .blend files - the only thing that didn't work with that version is it couldn't load your demo blend files (from your website), nor could I display the "System" tab in "User Pref" - both would result in a crash. clinfo.exe (from ATI) also crashes on load.
From the cmd line:
blender.exe --factory-startup --debug-cycles
AL lib: (EE) UpdateDeviceParams: Failed to set 44100hz, got 48000hz instead
found bundled python: C:\Program Files\Blender Foundation\Blender\2.78\python
I0215 15:59:37.116869 8156 blender_python.cpp:182] Debug flags initialized to:
CPU flags:
CUDA flags:
Adaptive Compile: False
OpenCL flags:
I0215 15:59:37.226869 8156 device_cuda.cpp:1363] CUEW initialization failed: Er
ror opening the library
I0215 15:59:37.226869 8156 device_opencl.cpp:58] CLEW initialization succeeded.
Error: EXCEPTION_ACCESS_VIOLATION
Added subscriber: @michael2000
Added subscriber: @davehorner
windows 10 enterprise, 64bit
two GeForce GTX 560 not in sli mode.
nividia 376.53
Broken: (example: 2.69.7
4b206af
, see splash screen)Worked: (optional)
I was looking to upgrade my blender using choco packages. After upgrading to 2.78 I get
I tried uninstalling and reinstalling, strange the app still is on disk and even the downloaded msi it seems.
I would like to understand and help with resolution of this bug if possible.
Thanks.
http://dave.thehorners.com/
Which version of blender would you like to uninstall?
You selected to remove all versions of blender
C:\WINDOWS\system32>choco upgrade blender
Chocolatey v0.10.3
Upgrading the following packages:
blender
By upgrading you accept licenses for the packages.
You have blender v2.70.1.20140513 installed. Version 2.78 is available based on your source(s).
chocolatey-uninstall.extension v1.1.0 [Approved]
chocolatey-uninstall.extension package files upgrade completed. Performing other installation steps.
Installed/updated chocolatey-uninstall extensions.
The upgrade of chocolatey-uninstall.extension was successful.
blender v2.78 [Approved]
blender package files upgrade completed. Performing other installation steps.
The package blender wants to run 'chocolateyInstall.ps1'.
Note: If you don't run this script, the installation will fail.
Note: To confirm automatically next time, use '-y' or consider setting
'allowGlobalConfirmation'. Run 'choco feature -h' for more details.
Do you want to run the script?(- [x]es/- [x]o/- [x]rint): y
Downloading blender 64 bit
WARNING: C:\Users\dhorner\AppData\Local\Temp\chocolatey\blender\2.78\blender-2.78a-windows64.msi is of content type text/plain; charset=UTF-8
Progress: 100% - Completed download of C:\Users\dhorner\AppData\Local\Temp\chocolatey\blender\2.78\blender-2.78a-windows64.msi (84.01 MB).
Download of blender-2.78a-windows64.msi (84.01 MB) completed.
Hashes match.
Installing blender...
blender has been installed.
Environment Vars (like PATH) have changed. Close/reopen your shell to
see the changes (or in powershell/cmd.exe just type
refreshenv
).The upgrade of blender was successful.
Chocolatey upgraded 2/2 packages. 0 packages failed.
See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log).
C:\WINDOWS\system32>cd rC:\Program Files\Blender Foundation\Blender
C:\WINDOWS\system32>cd C:\Program Files\Blender Foundation\Blender
C:\Program Files\Blender Foundation\Blender>blender
C:\Program Files\Blender Foundation\Blender>blender --factory-startup
C:\Program Files\Blender Foundation\Blender>choc uninstall blender
'choc' is not recognized as an internal or external command,
operable program or batch file.
C:\Program Files\Blender Foundation\Blender>choco uninstall blender
Chocolatey v0.10.3
Uninstalling the following packages:
blender
blender v2.68.1
blender has been successfully uninstalled.
blender v2.69
blender v2.70.1
The package blender wants to run 'chocolateyUninstall.ps1'.
WARNING: @{DisplayIcon=C:\Program Files\Blender Foundation\Blender\blender.exe; DisplayName=Blender; DisplayVersion=2.70a; NoModify=1; NoRepair =1; Publisher=Blender Foundation; UninstallString="C:\Program Files\Blender Foundation\Blender\uninstall.exe"; URLInfoAbout=http://www.blender.org/; PSPath=Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Blender; PSParentPath=Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall; PSChildName=Blender; PSProvider=Microsoft.PowerShell.Core\Registry} @{AuthorizedCDFPrefix=; Comments=; Contact=foundation@blender.org; DisplayVersion=2.78.1; HelpLink=; HelpTelephone=; InstallDate=20170216; InstallLocation=C:\Program Files\Blender Foundation\Blender; InstallSource=C:\Users\dhorner\AppData\Local\Temp\chocolatey\blender\2.78; ModifyPath=MsiExec.exe /I{437221A8-91D1-42A0-9E04-0AD64B502374}; Publisher=Blender Foundation; Readme=; Size=; EstimatedSize=322186; UninstallString=MsiExec.exe /I{437221A8-91D1-42A0-9E04-0AD64B502374}; URLInfoAbout=; URLUpdateInfo=; VersionMajor=2; VersionMinor=78; WindowsInstaller=1; Version=38666241; Language=1033; DisplayName=Blender; PSPath=Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{437221A8-91D1-42A0-9E04-0AD64B502374}; PSParentPath=Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall; PSChildName={437221A8-91D1-42A0-9E04-0AD64B502374}; PSProvider=Microsoft.PowerShell.Core\Registry}.Count matches found!
WARNING: To prevent accidental data loss, no programs will be uninstalled.
WARNING: Please alert package maintainer the following keys were matched:
WARNING: - @{DisplayIcon=C:\Program Files\Blender Foundation\Blender\blender.exe; DisplayName=Blender; DisplayVersion=2.70a; NoModify=1; NoRepair =1; Publisher=Blender Foundation; UninstallString="C:\Program Files\Blender Foundation\Blender\uninstall.exe"; URLInfoAbout=http://www.blender.org/; PSPath=Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Blender; PSParentPath=Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall; PSChildName=Blender; PSProvider=Microsoft.PowerShell.Core\Registry}.DisplayName
WARNING: - @{AuthorizedCDFPrefix=; Comments=; Contact=foundation@blender.org; DisplayVersion=2.78.1; HelpLink=; HelpTelephone=; InstallDate=20170216; InstallLocation=C:\Program Files\Blender Foundation\Blender; InstallSource=C:\Users\dhorner\AppData\Local\Temp\chocolatey\blender\2.78; ModifyPath=MsiExec.exe /I{437221A8-91D1-42A0-9E04-0AD64B502374}; Publisher=Blender Foundation; Readme=; Size=; EstimatedSize=322186; UninstallString=MsiExec.exe /I{437221A8-91D1-42A0-9E04-0AD64B502374}; URLInfoAbout=; URLUpdateInfo=; VersionMajor=2; VersionMinor=78; WindowsInstaller=1; Version=38666241; Language=1033; DisplayName=Blender; PSPath=Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{437221A8-91D1-42A0-9E04-0AD64B502374}; PSParentPath=Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall; PSChildName={437221A8-91D1-42A0-9E04-0AD64B502374}; PSProvider=Microsoft.PowerShell.Core\Registry}.DisplayName
Skipping auto uninstaller - No registry snapshot.
blender not uninstalled. An error occurred during uninstall:
Unable to find package 'blender'.
refreshenv
).Chocolatey uninstalled 4/5 packages. 1 packages failed.
Uninstalled:
Failures
If a package uninstall is failing and/or you've already uninstalled the
software outside of Chocolatey, you can attempt to run the command
with
-n
to skip running a chocolateyUninstall script, additionallyadding
--skip-autouninstaller
to skip an attempt to automaticallyremove system-installed software. This will only remove the packaging
files and not things like software installed to Programs and Features.
If a package is failing because it is a dependency of another package
or packages, then you may first need to consider if it needs removed
as it is typically installed as a dependency for a reason. If you
decide that you still want to remove it, head into
$env:ChocolateyInstall\lib
and find the package folder you wantremoved. Then delete the folder for the package. This option should
only be used as a last resort.
Chocolatey v0.10.3
blender
refreshenv
).Chocolatey uninstalled 1/1 packages. 0 packages failed.
C:\Program Files\Blender Foundation\Blender>choco install blender
Chocolatey v0.10.3
Installing the following packages:
blender
By installing you accept licenses for the packages.
blender v2.70.1.20140513 already installed.
Use --force to reinstall, specify a version to install, or try upgrade.
Chocolatey installed 0/1 packages. 0 packages failed.
Warnings:
Chocolatey v0.10.3
blender
refreshenv
C:\Program Files\Blender Foundation\Blender>refreshenv
Refreshing environment variables from registry for cmd.exe. Please wait...Finished..
C:\Program Files\Blender Foundation\Blender>choco uninstall -y blender
Chocolatey v0.10.3
blender
blender is not installed. Cannot uninstall a non-existent package.
Chocolatey uninstalled 0/1 packages. 1 packages failed.
Failures
with
-n
Did you know the proceeds of Pro (and some proceeds from other
licensed editions) go into bettering the community infrastructure?
Your support ensures an active community, it makes you look smarter,
plus it nets you some awesome features!
https://chocolatey.org/compare
C:\Program Files\Blender Foundation\Blender>choco install -y blender
Chocolatey v0.10.3
blender
blender package files install completed. Performing other installation steps.
File appears to be downloaded already. Verifying with package checksum to determine if it needs to be redownloaded.
Hashes match.
Hashes match.
refreshenv
).The install of blender was successful.
Chocolatey installed 1/1 packages. 0 packages failed.
C:\Program Files\Blender Foundation\Blender>blender --factory-startup --debug-cycles
"blender-2.78-384b7e1-win64-vc14.zip"
and
blender-2.78-781507d-win64.zip
from buildbot are working no issues.
Added subscribers: @Sergey, @mont29
@davehorner Seriously! Please:
So considering your case cleared.
@michael2000
That means you have a serious GPU driver issue, we cannot really help here, if even basic diagnostic tool from very vendor of the GPU crashes…
Not being able to update the drivers is also not good news, but it’s a bit strange that it still crashes with software OpenGL. I would infer from your crash report from console that the issue is with OpenCL initialization, which could be perfectly explained by the old drivers.
There is some way to disable OpenCL checks at startup with envvar iirc, @Sergey should know about it?
In the mean while, please try the latest build from our buildbot, and try starting blender from command line that way:
CYCLES_OPENCL_TEST=true /path/to/blender
In order to disable OpenCL completely you should be using
CYCLES_OPENCL_TEST=NONE
environment variable.Setting CYCLES_OPENCL_TEST=NONE fixed the problem. Can also now access the System tab in user preferences and load your demo blend files without crashing. Thanks for the quick help!
With this OPENCL environment variable set, will it prevent any features from working?
You won’t be able to use OpenCL for GPU rendering with Cycles - which you probably already cannot do anyway.
I’ll close the report for now, OpenCL is rather touchy currently, and definitively needs the ultimate latest drivers (and usually very recent hardware too) to have a hope of it working…
PS: do not, absolutely not, use the GPU drivers featured by your laptop vendor, those are never really maintained and nearly always way too old. Try to download them directly from AMD website, it’s the only way to get latest one, hopefully this will fix your issue.
