Possible NaNs with refractive BSDF
Open, ConfirmedPublic
i7 3930k
40GB RAM
Nvidia GeForce GTX660 (driver version 21.21.13.7653)
windows 10 pro, 64-bit
2.78a e8299c8
cycles renders artifacts, that look like NaN errors: see image
open scene NaN_bug.blend, set viewport to "Rendered" or press f12 to render, while it's cooking, these white dots start to pop up
Doesn't look like a bug, just reflections from the lamp. Disable MIS for the lamp and the birght spots go away.
@Sergey Sharybin (sergey) Can you confirm?
Sergey Sharybin (sergey) triaged this task as "Confirmed" priority.Thu, Feb 23, 11:42 AM
Sergey Sharybin (sergey) claimed this task.
The noise is coming from caustics i think. Usually using Filter Glossy will help, but it has no effect on Sharp distribution. Doing something like D2416 will help here.
At least that's what i see from quick investigation and might be wrong.
In any case, unsolvable noise is not a good thing anyway and disabling MIS is not really a solution in real production scenes.
Maybe @Brecht Van Lommel (brecht) can throw some ideas here as well :)
I think D2416 would be good for this case.
The other workaround is to use the transparent shadows trick, which might be good to add as a builtin feature of the glass BSDF node:
https://docs.blender.org/manual/en/dev/render/cycles/optimizations/reducing_noise.html#glass-and-transparent-shadows
Add Comment
