Animation node 1.6 cannot be installed in Blender 2.78b 64bit win version #50729
Closed
opened 2017-02-19 22:42:54 +01:00 by Gabor Lowy · 5 comments
win7 64 bit
NVidia geforce
Broken: (example: 2.69.7 4b206af, see splash screen)
when trying to install animation nodes to the latest official version it sends a message referring to line 330 and a missing numpy library that was needed for plugin to work
try to install animated nodes 1.6 to blender 2.78b
**System Information** Operating system and graphics card win7 64 bit NVidia geforce **Blender Version** Broken: (example: 2.69.7 4b206af, see splash screen) Worked: (optional) **Short description of error** when trying to install animation nodes to the latest official version it sends a message referring to line 330 and a missing numpy library that was needed for plugin to work **Exact steps for others to reproduce the error** try to install animated nodes 1.6 to blender 2.78b Based on a (as simple as possible) attached .blend file with minimum amount of steps
Author
Author
Added subscriber: @GaborLowy
Member
Added subscriber: @Blendify
Member
Aaron Carlisle self-assigned this 2017-02-19 22:48:20 +01:00
Member
The animation nodes add-on is not distributed with the official version of Blender. Please report this issue with the author(s) of the add-on instead.
2 Participants
Reference: blender/blender-addons#50729
