Texture Paint 'Bleed' is angled along UV edges #50831
11 Participants
Reference: blender/blender#50831
Windows 10
Nvidia GTX 970
Broken: 2.78a and 2.78c (tested on both of these)
When using the texture paint section of Blender, if the 'Bleed' setting is set to anything above 0, you will see that when painting along an edge of a UV in the 3D Texture Paint mode, the bleed works fine from the first vertex, but is angled towards the next vertex, meaning the bleed isn't consistent at all.
Added subscriber: @autumnpioneer
#52453 was marked as duplicate of this issue
Added subscriber: @biliogadafr
I encountered the same problem, so I decided to add pictures
This is especially a problem when I need to paint around holes in UV.
Added subscriber: @dfelinto
Please, as per the bug report guideline attach a file even if it's super simple.
Added subscriber: @mont29
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
I've prepared required scene:
BLEED_BUG.blend
Things to notice from this test scene:
Thanks, reopening then.
Any update? This is pretty detrimental to my workflow and a lot of artists i know, haven't seen any changes in 5 months
Added subscriber: @Stefan_Werner
Added subscriber: @ChameleonScales
It's not a bug but the behavior of the feature is a bit cheap.
The way it extends the pixels is as shown in this image (according to my experiments) :
Even with quads, it extends around the hidden triangles with the same method, which explains the non parallelism with the edges. Of course the edge inside the quad (the diagonal) doesn't get extended, as don't all the edges inside a UV island.
You can see it more clearly on these 2 examples (I added yellow lines to show the hidden triangles) :
The big question is : is this method the only possible one to allow fast enough responsiveness or can a better one be developed and work in real-time ?
Since this feature came out in 2.49 I'm guessing the modern computers can handle a better method.
What do you think b3d devs ?
I assigned you because you were assigned to this one https://developer.blender.org/T43709. It may be the same issue but I'd like to know if you have an answer to my question above.
more information:
Linux Manjaro 64-bit
GeForce GT 640
Broken: 2.79 RC1 down to 2.76
Worked: 2.75a and previous versions
Up until 2.75a, the texture brush bleed performed on quads using the bisectors of the quads :
but since 2.76 up until 2.79 RC1, it performs on the triangles that compose the quads :
this brought undesirable results such as an uneven thickness of the bleeding :
increasing the bleed value is not a good way to counteract this problem since it increases the chances of bleeding into another UV island or bleeding inside the very island we're painting in, as shown by the white arrows here (a texture stencil was used in the brush to make it visible everywhere) :
Exact steps for others to reproduce the error:
do the same in any later version
Added subscriber: @brecht
Added subscriber: @Psy-Fi
No point in keeping twice the same report open…
Also, @ChameleonScales, please avoid doing triaging tasks yourself unless you know what you are doing, @Psy-Fi is not currently active and doubt he will handle bug reports currently!
ok, sorry for that.
Added subscriber: @Jau
Hello,
Any news about this ? This functionality is useless this way, which is catastrophic when you need to paint a mask (ex : before exporting to Unreal Engine)
Added subscribers: @ideasman42, @pk-nb
Hi there—I wanted to let you know I took at a look at this bug. I ran into this issue originally when going through the blender cloud game asset tutorials. There are a couple things going on here in the latest blender. I was able to fix one miscalculation for tris but ran into a blocker with quads.
I believe the source of this bug is from the change to move to tri-data only within
source/blender/editors/sculpt_paint/paint_image_proj.c
. Specifically, this diff https://developer.blender.org/rBS416d164fecae8aeaa035c3bc2d47f7c07c970e48 from @campbellbarton.For the miscalculation with tris: it appears the bleed calculation was incorrectly using the edge normal with an edge rather than using a point normal. You can compare the difference with the patch and blend file provided here. Both are set to a bleed of 16px.
uv_patch.patch
problem-bleed.blend
Note that I fixed the "sawtooth" and corrected the bleed amount by fixing the normal calculation. Unfortuantely, there is still tri overextension for quads as you can see with the following screenshots.
After this change I realized it seems impossible to calculate the proper bleed for quads with tri-data alone. It seems like the bleed calculation is just different for quads and tri. Unfortunately with the change made from that diff we no longer have the quad info. I'm hoping for context for the change but I fear to fix this will require a revert back to using special cases for quads or else find another way to calculate bleed. My guess is that this was a refactor. Thanks for looking at this, and hopefully this helps!
Added subscriber: @dacanizares
I don't know if this it's related with this kind of errors: https://imgur.com/a/3g9IuMe
Any news about this? :(
@dacanizares it is related. Read my previous post explaining why this happens: https://developer.blender.org/T50831#450759
@ChameleonScales Thanks! Any idea if this is going to be solved for 2.8?
@dacanizares no idea, sorry.
Added subscriber: @LucaRood-3
Solved by @LucaRood-3 in
871248a77d
and10d9a2494f
