2.78a/2.78c problem with multiple xscreens (cursor capture broken while navigating in blender)
Closed, DuplicatePublic
X.Org X Server 1.12.3
ATI with fglrx driver
Broken: tested 2.78a and 2.78c
Worked: 2.77 #22a2853
if you have seperate xscreens (:0.1, :0.2, :0.3) and pan the view with middlemousebutton in blender running on screen :0.0 for example. the cursor can get grabbed by another screen, for example :0.1
but imho cursor should end up where the panning got started?!
as described above, works with any file...
Joey Ferwerda (TheOnlyJoey) triaged this task as Confirmed priority.Mar 6 2017, 5:05 PM
Can confirm, this is a quite specific issue though, windowing is a bit complex so i don't know if this will be a trivial fix.
