FBX exporter animation artefacts
Open, NormalPublic
Windows 10
GTX 970
Blender 2.78c
Exporting an animation to FBX produces artefacts when viewing the results either through FBX Review or when importing back into Blender
Open the attached Blender file and hit play to observe the animation. Note how the feet are perfectly stationary while the character bends its knees.
Now export to FBX. In the FBX export panel, under animation, set Simplify to zero and uncheck the All Actions check box. Enter a filename and click on the Export FBX button.
Now either view with FBX Review or import back into Blender, set the end frame to 40 and play the animation. Observe how the feet are no longer stationary.
Below is the blender file for testing.
FBX exporter bakes and applies some simplification to animations (to save some space). Setting Simplify parameter to zero in Animation settings of the exporter should fix that.
We do not handle user support on this tracker, only bug reports. User forums like blenderartists.org or blender.stackexchange.com should be used for that matter.
Thanks for your reply Bastien,
I am setting Simplify to zero (please see my instructions for reproducing the problem) and this is still happening.
Hence why I think this is a bug.
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Normal.
Eeek, OK, sorry, missed that part of your description somehow :|
Can confirm the issue, not sure where it comes from… off hands would suspect some floating point precision issue, but will have to check further.
