Wrong view rendering mode, on orthographic view , black rendering of some glossy surface.
Lubuntu 16.04 Intel® HD Graphics 5500
Broken: (2.78c e92f2352830, and 2.78.4 e8021f5e3b)
Hi, I found this bug some time ago, but I was hoping someone would report, it did not happen and so it's up to me. This is an error rendering of some shaders from above, in the orthographic view. I attached is the file with the error clearly visible.
Open the file and on top view port, change display shading mode to rendering mode.
Bastien Montagne (mont29) triaged this task as "Confirmed" priority.
Actually, am getting a crash here when trying to render from top view with debug build:
blender: /home/i74700deb64/blender/__work__/src/intern/cycles/kernel/./closure/../closure/bsdf_microfacet_multi.h:90: ccl::float3 ccl::mf_sample_vndf(ccl::float3, ccl::float2, ccl::float2): Assertion `isfinite(slope_x)' failed.
@Sergey Sharybin (sergey) assigning to you by default since it’s Cycles issue… ;)
Sergey Sharybin (sergey) closed this task as "Resolved".Mar 20 2017, 3:03 PM
Fixed this in rB18bf900. Thanks for the report!
