UV Map random swap - with multiple materials and UV Maps
Windows 7 64-bit
GeForce GTX 680
Broken: 2.78c official release
Worked: 2.78a official release
When an object has more than 1 material and more than 1 UV Map (each material using a different UV Map in the material nodes), occasionally a material will use the incorrect UV Map during animation. On average, it happens around 4-8 times per 100 frames.
Very rarely it might crash.
I could not reproduce this with only 1 material and multiple UV Maps.
The attached file has 1 object with 2 materials, each using a different UV Map.
  1. open file and Render Animation
  2. check animation result
If same problem occurs, a dot will move occasionally (uses different UV map) on a few frames.
In my testing, the problem doesn't occur in the following situations:
  1. 'Open Shading Language' enabled
Which is not very helpful when depending on GPU rendering
  1. 'Persistent Images' enabled
Not sure yet how this would affect more complex animation
I'm testing the latest build, and I cannot reproduce the issue any more.
Tested on
So whatever happened, it seems fixed
Dalai Felinto (dfelinto) closed this task as Resolved.May 22 2017, 12:39 PM
Dalai Felinto (dfelinto) claimed this task.
Closing then. Thanks for the report, and hi @Sacha Goedegebure (sago) :)
Okay, let's hope it stays resolved.
And good luck with bug solving!
