Pressure sensitivity no longer works for HUION graphics tablet with resent Linux kernel #50961
15 Participants
Reference: blender/blender#50961
Arch Linux 4.10.2-1-ARCH
GTX 1070 with Nvidia driver
Broken: 2.78c , 2.78b and 2.78a
Worked: Worked before upgrading to 4.10. Works fine in 4.8.11-1-ARCH
After updating my system the pressure sensitivity from a HUION H610 no longer works. The pressure sensitivity does still work in other programs such as GIMP, MyPaint and Krita.
Other notes:
I have noticed that the input devices listed in $xinput are different concerning the Huion tablet from Linux 4.8 to 4.10
In 4.8.11-1-ARCH:
$ xinput | grep HUION
HUION TopwinT261 Pen id=14 [slave pointer (2)]
HUION TopwinT261 Mouse id=15 [slave pointer (2)]
HUION TopwinT261 Consumer Control id=16 [slave pointer (2)]
HUION TopwinT261 System Control id=17 [slave keyboard (3)]
HUION TopwinT261 Keyboard id=18 [slave keyboard (3)]
In 4.10.2-1-ARCH:
HUION TopwinT261 Pad id=10 [slave pointer (2)]
HUION TopwinT261 Consumer Control id=11 [slave pointer (2)]
HUION TopwinT261 Pen Pen (0) id=16 [slave pointer (2)]
HUION TopwinT261 Pen id=9 [slave keyboard (3)]
HUION TopwinT261 Consumer Control id=15 [slave keyboard (3)]
Thanks.
Added subscriber: @datadump
#51504 was marked as duplicate of this issue
Added subscriber: @Blendify
Added subscriber: @atharvakulkarni
@atharvakulkarni could you try this patch?
Added check for
pen
- which may solve the problem. Otherwise it prints out stylus & types.@ideasman42 yeah I tried that patch, but that didn't solve the issue.
I got the following output:
@ideasman42 Got any idea where to find the bug?
Added subscriber: @Sergey
@atharvakulkarni, you can test something like P485 to try getting idea whether stylus gets rejected by something else.
Please also note that we can only fix bugs which we can reproduce, and this one is not reproducable without specific hardware. We'll be happy to help you trouibleshooting the issue on #blendercoders IRC room at irc.freenode.net tho!
Added subscriber: @JesusBalbastro
Hello, I think I have a solution to this. I have a similar tablet [Huion 540] with the same problem. The solution is to use xinput to disable some duplicates entries the device makes.
Disabling id 17 like so
makes pressure work again.
I don't know if this problem is blender's or the kernels.
I'm on Arch, Linux Kernel 4.9.56-1-lts
Added subscriber: @allen-marshall
I think I am having the same issue. I have a Monoprice tablet (product ID 10594), which I think is just a Huion H610 with different branding. (It has the same specs, same appearance, and works with the Huion driver on Windows.) Pressure sensitivity doesn't work in Blender 2.79 on either Ubuntu 17.04 or 17.10, but works in Krita. I also tried a Blender 2.80 build (blender-2.80-83de7c4094b-linux-glibc219-x86_64) and got the same problem. Pressure sensitivity works correctly for me in Blender 2.79 on Windows 10.
As in @JesusBalbastro's situation, the problem seems to be related to the fact that the tablet creates multiple xinput entries. I tried uncommenting some printfs in GHOST_SystemX11.cpp and got these results when running Blender 2.79 on the command line.
It appears that there is a TABLET device entry named "10594 Pen" and a STYLUS device entry named "10594 Pen Pen (0)", and the former gets detected as a stylus first, causing the latter to not be used as a stylus. I tried modifying the code in GHOST_SystemX11.cpp so that a TABLET device would not be considered a stylus. When I did this, the STYLUS device was detected as a stylus and pressure sensitivity worked. It looks like forcing GHOST_SystemX11::refreshXInputDevices to skip over the "10594 Pen" device fixes the issue for me. Unfortunately, disabling the "10594 Pen" device in xinput doesn't seem to work for me. Also, if I set my xorg configuration to ignore the device, it no longer shows up in xinput, but Blender still detects it, resulting in no pressure sensitivity.
The workaround I am using for now is to change line 2214 of GHOST_SystemX11.cpp from
to
I assume this workaround could cause trouble with some brands of tablets, but it seems to work well with the one I have. I would like to find a workaround that doesn't require modifying the Blender source, but @JesusBalbastro's solution above didn't work for me.
I would be happy to help debug the issue, as I have an affected tablet and some software development experience. However, I have very little experience with handling X input devices.
Update: I must have done something wrong when I tried blacklisting the "10594 Pen" device in my xorg configuration, because I just tried it again, and instead of working with no pressure sensitivity, the tablet didn't work at all. Maybe I disabled the wrong device the first time I tried it.
I don't know why I didn't mention I enabled the device again. Somehow I didn't notice I did.
What works for me is to disconnect the tablet, run blender and disable and enable the device.
@JesusBalbastro That seems to work for me. Thanks for the workaround!
Added subscriber: @Lucidreason
Thank you, it works for me either.
Added subscriber: @sypher7
Had this same issue with my Huion GT-220v2 on Ubuntu 17.10.
The workaround provided by @JesusBalbastro works for me as well.
Added subscriber: @indefini
Added subscriber: @underpants-enthusiast
Added subscriber: @MikhailGavrilec
I have HUION Q11K. and this workaround didn't help me to solve the problem
Added subscriber: @iszotic
Huion H58L and also worked for me... Blender 2.79.b+dfsg0-1, and Blender 2.8
9b817bc168
after the grease pencil mergeEveryone commenting on this - please note that ticket is closed for some reason.
@ideasman42 - is there any way that you could reopen or does it perhaps need merging with unassigned issue #52929?
I have an UGEE M708 which, according to xinput, is a rebranded UC-LO(G)IC TABLET 1060 (which, again are rebranded HUION or vice-versa) and run Manjaro (Arch).
I tried the disconnect/reconnect/xinput disable/enable workaround with 2.79 release, master, and blender2.8 on kernels 4.17, 4.14 and 3.18 using both the built-in and digimend drivers with no luck. I had working tablet pressure in both Krita or MyPaint.
@allen-marshall's workaround of removing the
|| (device_info- [x].type == m_atom.TABLET)
check in GHOST_SystemX11.cpp works for me on master and blender2.8 - thanks for this.I've attached the output of
xinput list --long
andxinput test
for device id 17 in case it's of any use in getting to the root of the problem.Thanks all
xinput-list-long.txt xinput-test-uc-loic-tablet-1060-pen-pen-0.txt
