Attempting to install the Azure Batch add-on 0.1.1 (Failure) #51004
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#51004
MacOS "El Capitan". 10.11.6 (15G1217)
NVIDIA GeForce GT 750M 2048 MB
Blender Version Version 2.78 (2.78 2017-02-27, Blender
Broken: First time attempting to install it.
Worked: First install (failed).
**Traceback (most recent call last):
File “/Applications/blender.app/Contents/MacOS/../Resources/2.78/scripts/modules/addon_utils.py”, line 330, in enable mode = import(module_name)
File “/Users//Library/Application Support/Blender/2.78/scripts/addons/batchapps_blender/init.py”, line 41, in from batch apps import credentials
ImportError: No module named ‘batchapps’
Compiled the code into a zip file and installed but when it came to enable it then the error showed up.
Added subscriber: @elpidiovaldes
Added subscriber: @VukGardasevic
Since you're on Mac there was a problem with the initial upload of the Mac 2.78c version with some python libraries missing.
Be sure that you have a working version of 2.78c if you're using it. If that is the case, please try to re-download the 2.78c and reinstall it again, and let us know if it worked for you.
For more on the issues related to that check out tasks blender/blender#50821 and blender/blender#50889.
The exact error that you mentioned is already reported in #50746. The answer in that task also applies here - it's not an add-on officially maintained / hosted by Blender - it's not in release nor contribution. The maintenance is on the third party developer.
From the error message seems that a file is missing, or the path of the import is wrong. Possibly the folder name needs to be called
batchapps
instead ofbatchapps_blender
.A common problem is when you install the add-on from sites like zip archives there is a possibility that the path import names are hardcoded instead of relative. So, if the whole folder containing all the scripts has a different name to what is assumed in the script import - it'll throw an error.
Setting as incomplete until additional information is provided.
Added subscriber: @mont29
There is nothing related to missing module distributed with Blender here. And as said, we do not accept bug reports about third-party add-ons not distributed with Blender, those shall be reported to the add-on's author(s).
