Swap <version> and <lang> in the manual url #51081
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#51081
Who
https://docs.blender.org/manual/en/dev/
What
This task is to discuss switching from having the language first to having the version first in the url.
Why
The reason why we should change this is it would be much more logical and streamline.
Languages are version specific, for example, one version may add a language or remove move them.
Because the are language specific the current set up makes it very difficult for us to upload new releases.
See the below directory layout for the current approach then see the one following.
While we can make it work with the first version it would make things much more difficult.
With the later, all I have to do is make one 2.79 folder and give it someone to upload to the server
However, with the other, I have to give someone a 2.79 folder for each language.
This purposed solution will also make our JSON and js files in D2544 much easier to maintain.
When
This will need to be done before we move forward with versioning the manual (D2544, #49262)
How
@Sergey will have to edit some apache stuff on the server.
Added subscribers: @Sergey, @Blendify, @fsiddi, @Tobias
Ok, as i see now
dev
refers to a version, not to a developer's manual (obviously).Points to consider here goes as following.
The existing layout was agreed on, spent time on and used for quite some time now. There are shared links everywhere in the internets now, so changing layout will wither break links (which is totally undesirable) or will force us to have bunch of redirect rules (which are PITA to maintain and which can always break in the future as well). If we REALLY want to change this, it's not just a web server configuration, but also the manual builder machine and scripts which needs update and troubleshoot.
All this is either time consuming or useless for users of the manual.
Now answering some raised points.
I do not see how this is an issue with the current directory layout. You can have some nice 404 page for missing versions. It's not like changing directory layout magically solves the issue.
Do not see an issue here either. We already have script which deploys latest version of manual. It is trivial to use it to deploy any version of any language. It is not like building will ever support batched upload anyway.
I do not see a point here. In theory, you can just copy
dev
to{BLENDER_VERSION}
at a release file on server. Even with current layout it is doable with simple oneliner.Alternatively, you run builder scrit with a given version on all languages and they will deploy manual for a specified language. It's not like new language will appear for a release and not for the latest version.
I do not see how this is related. It is questionable which JSON format is easier to maintain and even if the "swapped" one is easier you can always transpose the language/version order at a runtime.
All in all, i would really suggest sticking to the current layout unless there are unsolvable issues. If there are unsolvable issues please mention them explicitly and not just vague "makes things difficult".
Added subscriber: @ideasman42
@Tobias agrees that it should be swapped.
Added subscriber: @JohnRoper
I agree. I believe that usability trumps in this case.
I changed my mind: Also language first is valid, because the language is common/static between the version. From this point of view it doesn't matter if xy is only offered since 2.78. And yes it makes no difference for the version switch (D 2544).
So if there are no benefits it would be better to use to the standard.
Talked on IRC a bit more. While swapping them would give nice benefits we decided to go with the standard.
