Improve keyboard usage for menu search popup #51087
22 Participants
Reference: blender/blender#51087
NA
Broken: example: 2.78
Worked: >new feature request<
when spacebar search menu popups and user start writing the required command, only down-arrow keyboard shortcut are allowed to select the required command, starting from first item on top.
It will be very useful and faster if also up-arrow can be usable to select the last item in the list (so starting from bottom).
See image as reference: green arrow show the required feature, red one is the only one actually working.
not an error, only UI usage improvement :)
Added subscriber: @blend-it
Added subscribers: @JulianEisel, @mano-wii
This does not seem complicated, and would really be useful!
@JulianEisel, could you take a look?
Added subscriber: @ideasman42
Seems reasonable, moved to quick hacks since this is a nice one for new developers.
I always propose easy and fast hacks, but unfortunately I'm not a coder, so I can't do it myself (and I don't want broke something) ;)
Added subscriber: @karinafantonio
Hi, first-time contributor here! I've created a patch with this new feature, plus a short screencast attached.
One issue evident in the screencast is how long it takes to wrap from the top of the searchbox to the bottom for long item lists. This happens because I'm calling
ui_searchbox_update
in a loop, but I don't know any other way to access the end of the item list/the size of the item list. Furthermore, where is the value of items.more assigned?searchbox_wrap.diff
searchbox_wrap_demo.mp4
Any feedback is greatly appreciated!
Hi @karinafantonio,
I liked your code but one thing worries me...
It's this part:
We can have about 2000 items in a list
ui_searchbox_update
in a loop can be quite inefficient.So, if it were not for this detail, I think the patch would already be good to commit.
Ahh, I see. Here's the updated patch with that part removed.
Using (and making!) this patch feels really nice!
searchbox_wrap.diff
Thanks for working on this feature :)
I nothing understand about the code, but if there are a performance issue, I can suggest you can trigger your routine only when:
Hi, no problem, it was fun to do and a nice feature to have! ^^
The patch adds scrolling from bottom to top for all list sizes, and scrolling from top to bottom only when the entire list is visible (so when the list is <= 10 items). No performance issues at all for these cases, there are only issues for the case of wrapping from top to bottom with large lists with many not-visible items (so my latest patch disabled wrapping in this case).
@blend-it changing behavior based on number of letters typed will seem buggy from user perspective.
I don't see why wrapping the list would have to be a slow operation.
@ideasman42 About the number of letters typed, I understand your point, but with less of 3/4 letters the list is so long and user can't see the bottom, so I think nobody try to scroll from an "invisible" bottom.
Anyway, I can't compile and try to check performance, so if you don't find this kind of issues, no problem!
Thanks to all and I hope to find the feature in 2.79 ;)
Added subscriber: @Dinulja
the patch was not included in 2.79.... it's possible for 2.79a? :)
Added subscriber: @kouhaku111
where can i find the definition of data->active, items.totitem, items.more and items.offset
Added subscriber: @sandstorm
Is there a commit for this patch? I compiled the latest version and it does not work as in the video.
Added subscriber: @durgesh
I am working on improving the patch
Added subscriber: @REMBO
Is this task not done? Can I progress it?
Added subscriber: @KalyanS
This comment was removed by @KalyanS
Added subscriber: @Fre2910
Added subscriber: @carlosedubarreto
Added subscriber: @don.miguel
Hello, the patch does not seem to work so I worked on a different approach. If anyone is interested, here is my submitted patch .
Added subscriber: @Faraz-007
Removed subscriber: @Faraz-007
Added subscriber: @lemagedurage
Hi there!
Since I couldn't get previous patches to apply / work properly, and because I'm doing a course for my university, I dived into this issue too.
This issue is harder than it might look because the underlying data structure is an iterator, which doesn't expose the total amount of search results. Wrapping from the bottom item to the top one is trivial, but wrapping from the top item to the bottom one is not.
Based on Karina's and Don's work, I created a somewhat simplified patch here that should work fine on the current master branch.
Testers and feedback are welcome. I hope this little feature can be added soon.
Added subscriber: @propersquid
Added subscriber: @paul2t
Hello Jaap,
You need to create a new Revision from this diff and attach it to this task.
Then, someone will review it.
Improve keyboard usage for spacebar search menuto Improve keyboard usage for menu search popupAdded subscriber: @Luckeneder
I tried the diff from Jaap, and i can comfirm it works
interface_region_search.c
Added subscriber: @AlexCarter
{F9611275}Ok so I took a look into it and found a way that both wraps to the actual bottom of search list (not just the bottom of what is visual) and also does so without a while loop. Line 1004 in
interface_template_search_menu.c
creates a variablefiltered_amount
which is the full size of the search array so to theuiSearchItems
struct I added an intsize
and a setter function so now the total size of the search array is stored and accessible to us back in theui_searchbox_select
function.Added subscriber: @jenkm
I don't mind being able to jump to the first/last item, e.g. with the Page Up / Page Down.
But this endless scrolling doesn't look like a good idea.
We already have this issue in menus and enums, when it is hard to stop at the first/last item. It requires increased accuracy and multiple attempts.
A good example is scrolling the enum on mouse hover with ctrl+wheel. It would be much more useful if scrolling stopped at the first/last item.
I'm not even talking about scrolling with a macbook trackpad, the current behavior with endless scrolling is just terrible, it does not allow you to use a quick swipe to scroll to the beginning/end.
Or another example is a preview menu like a Brushes or MatCap, it's just terrible if it's looped, if the previews are similar then you just don't understand when you've reached the end.
Added subscriber: @3di
I think continuous scroll should be OK on the f3 menu because it's a fixed size and so will never go off screen. The reason the continuous scroll is such a problem on shift a menus is because those menus can grow off screen, and because the mouse scroll wheel is not very accurate, it's really tricky to select the offscreen options without accidentally going back to the bottom/top
I think nice additions would be:
Added subscriber: @Camilo-Villavicencio
Hi! I was able to implement a combination of the first two additions Michael listed above.
Now, pressing the Page Up and Page down keys on Windows on the f3 menu will first select the top or bottom list item of the menu respectively. Pressing either button again will then jump up/down a page in the f3 menu.
I've attached a diff with my additions, as well as a short video of the feature in use.
{F13047150}blender_3lzPkau4nh.mp4
Feel free to let me know what you guys think!
