Smoke domain values not remembered after toggling between domain and flow tabs
Closed, InvalidPublic
Ubuntu 16,04 64bit and Intel Haswell Mobile graphics card
Broken: (example: 2.78c
Changing of any(?) settings in either the Domain, Flow or Collision tabs for the Smoke Physics, change to a different tab and then back again and your changes have been ignored and the original default value is displayed{F534404}
Based on the attached .blend file with minimum amount of steps,
Goto Physics Smoke for the Smoke domain.
In the Domain tab change the Resolution Divisions from 32 to 44, click the Flow tab, then go back to the Domain tab and the Resolution now displays the original value of 32
This is not a bug since when toggling between Domain, Flow, Collision and None, resets the modifier for the active object in order to change its type for the simulation, that is the domain object becomes a flow object in your example (developer note: the settings for each category are stored in different structs).
Thanks for the report, although since it is not a bug per se, I'm closing this ticket.
